Ir para o conteúdo principal
Sony M-430 Microcassette-Corder Back Cover Replacement
O que você precisa
  1. Sony M-430 Microcassette-Corder Back Cover Replacement, Battery: passo 1, imagem 1 %32
    • Find the arrow on the battery cover on the back of the device.
    • While pressing down on the arrow, slide the cover towards the bottom of the recorder until it clicks.
  2. Sony M-430 Microcassette-Corder Back Cover Replacement: passo 2, imagem 1 %32 Sony M-430 Microcassette-Corder Back Cover Replacement: passo 2, imagem 2 %32
    • Lift the cover and remove the batteries.
  3. Sony M-430 Microcassette-Corder Back Cover Replacement, Back Cover: passo 3, imagem 1 %32 Sony M-430 Microcassette-Corder Back Cover Replacement, Back Cover: passo 3, imagem 2 %32
    • Remove the battery cover by first tilting it so it is at a right angle with the rest of the device.
    • Next, twist it to the side as shown in the second picture. The lid should simply snap off.
    • Potential for device damage: be careful not to apply too much force, as the lid may break.
  4. Sony M-430 Microcassette-Corder Back Cover Replacement: passo 4, imagem 1 %32 Sony M-430 Microcassette-Corder Back Cover Replacement: passo 4, imagem 2 %32
    • Use a #00 Phillips head screwdriver to remove the four (1.7x16 mm) screws from the back case.
    • Next, use the same screwdriver to unscrew the (1.7X5 mm) screw, which is located inside the battery compartment.
  5. Sony M-430 Microcassette-Corder Back Cover Replacement: passo 5, imagem 1 %32
    • Use a spudger to push in the two tabs located on the bottom of the device.
    • It works best to push the tabs at an upward angle (towards the top of the battery compartment). It may take a decent amount of force in order to push in the tabs.
  6. Sony M-430 Microcassette-Corder Back Cover Replacement: passo 6, imagem 1 %32
    • With a firm grip on the larger half, remove the back cover by lifting first on the battery area.
    • The back cover should lift cleanly off.
Conclusão
Uma outra pessoa concluiu este guia.
Matt Teare
Membro desde: 01/20/12
35 Reputação
Autoria de 3 guias
Equipe
Cal Poly, Team 10-34, Amido Winter 2012 Membro de Cal Poly, Team 10-34, Amido Winter 2012
CPSU-AMIDO-W12S10G34
4 Membros
Autoria de 7 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 7
Ao todo: 2,196
