Ir para o conteúdo principal
Sony Laptop VGN-FE31Z LCD Repair
O que você precisa
  1. Sony Laptop VGN-FE31Z LCD Repair, Sony Laptop VGN-FE31Z LCD Repair: passo 1, imagem 1 %32
    • This problem has already happened in many electronic devices in my home, almost every year. The solution is simple: to dismantle the machine completely and remove all traces of soil, ants and dirt.
    • Researching a little on Google, I found the repair manual of the Sony Vaio VGN FE31Z at this address: http://www.givemefile.net/smanuals/noteb...
    • Procedures carefully dismantling the equipment until the LCD. While performing this procedure, I noticed that the ants began to move from side to side, Laptop Keyboard leaving and entering the LCD.
    • The ants have focused on two points: the LVDS and backlight ballast.
    • I removed all electrical parts and proceeded to clean all plastic casing of the laptop, with water and detergent. While the coating was dry, I used isopropyl alcohol to clean the traces of soil. I applied a clean contact solution and the other in LVDS connectors.
    • I mounted the LCD, putting a little poison for ants to prevent future infestations.
Conclusão
Documentos anexados
Djair Guilherme
Membro desde: 04/28/10
114 Reputação
Autoria de 1 guia
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 6
Últimos 30 dias: 9
Duração total: 2,411
