Ir para o conteúdo principal
Sony KDF-E60A20 Lamp Replacement
O que você precisa
  1. Sony KDF-E60A20 Lamp Replacement, Lamp: passo 1, imagem 1 %32 Sony KDF-E60A20 Lamp Replacement, Lamp: passo 1, imagem 2 %32 Sony KDF-E60A20 Lamp Replacement, Lamp: passo 1, imagem 3 %32
    • Remove the two thumb screws.
  2. Sony KDF-E60A20 Lamp Replacement: passo 2, imagem 1 %32 Sony KDF-E60A20 Lamp Replacement: passo 2, imagem 2 %32 Sony KDF-E60A20 Lamp Replacement: passo 2, imagem 3 %32
    • With both thumb screws removed, the front bezel can now be easily pulled off. It is only held in place by three magnets.
    • With the bezel out of the way, there will be a small cover held in place by a crossbar and a thumb screw. Loosen the thumb screw and fold the bar out of the way.
    • The back of the lamp housing is now visible.
  3. Sony KDF-E60A20 Lamp Replacement: passo 3, imagem 1 %32 Sony KDF-E60A20 Lamp Replacement: passo 3, imagem 2 %32 Sony KDF-E60A20 Lamp Replacement: passo 3, imagem 3 %32
    • Loosen the 3mm Allen bolt. It will not come out of the lamp housing, but will loosen it to remove the lamp housing from the TV.
    • With the Allen bolt loose, pull the lamp houing slightly back and down,
    • this will remove the lamp in its housing.
  4. Sony KDF-E60A20 Lamp Replacement: passo 4, imagem 1 %32 Sony KDF-E60A20 Lamp Replacement: passo 4, imagem 2 %32 Sony KDF-E60A20 Lamp Replacement: passo 4, imagem 3 %32
    • Here is the old lamp and housing.
    • For the replacement, a complete lamp and housing was chosen. The lamp is individually available. There was not a big difference in cost, to justify the additional steps of replacing the lamp housing.
    • Install the new lamp and housing
  5. Sony KDF-E60A20 Lamp Replacement: passo 5, imagem 1 %32
    • Result of this $32 repair is a bright fully functioning TV
Conclusão
13 outras pessoas executaram este guia.
oldturkey03
Membro desde: 09/29/10
853.235 Reputação
Autoria de 123 guias
17Comentários do guia
Where did you purchase this bulb for $32?
Wendy Watson - Responder Compartilhar
Mine worked 4 3 hours then stayed off.
Love machine Guaranteed - Responder Compartilhar
I ordered a replacement housing with new bulb in it and with shipping it was 35. Ordered it thru Sears online and they sent it out next day air. It took five min to swap out
Joker - Responder Compartilhar
A y solutions
Thanks a lot. You saved me money
Alexander Ritchie - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 4
Últimos 7 dias: 14
Últimos 30 dias: 97
Ao todo: 26,198
