Ir para o conteúdo principal
Sony ICF-C1iPMK2 Speaker Replacement
O que você precisa
  1. Sony ICF-C1iPMK2 Speaker Replacement, Speaker: passo 1, imagem 1 %32 Sony ICF-C1iPMK2 Speaker Replacement, Speaker: passo 1, imagem 2 %32
    • Unscrew the 1 cm Phillips #00 screws.
    • Use spudger to loosen the back panel of the device.
  2. Sony ICF-C1iPMK2 Speaker Replacement: passo 2, imagem 1 %32 Sony ICF-C1iPMK2 Speaker Replacement: passo 2, imagem 2 %32 Sony ICF-C1iPMK2 Speaker Replacement: passo 2, imagem 3 %32
    • This step contains ribbon cables. Be careful to not bend or rip these fragile cables, to protect your device.
    • Slowly pull the back panel off until it separated from the main panel.
    • Carefully unplug all of the ribbon cables connecting the back panel to the main panel.
  3. Sony ICF-C1iPMK2 Speaker Replacement: passo 3, imagem 1 %32 Sony ICF-C1iPMK2 Speaker Replacement: passo 3, imagem 2 %32 Sony ICF-C1iPMK2 Speaker Replacement: passo 3, imagem 3 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Remove the power connector with a pair of ESD safe tweezers.
    • Remove the Aux port connector with a pair of ESD safe tweezers.
    • Slide the button panels out of the chassis.
  4. Sony ICF-C1iPMK2 Speaker Replacement: passo 4, imagem 1 %32 Sony ICF-C1iPMK2 Speaker Replacement: passo 4, imagem 2 %32 Sony ICF-C1iPMK2 Speaker Replacement: passo 4, imagem 3 %32
    • Unscrew the four 1 cm Phillips #00 screws and remove the speaker cover.
    • Unscrew the 1 cm Phillips #00 screws holding the speaker in place.
    • Remove the old speaker and insert the new one.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 7
Duração total: 88
