Ir para o conteúdo principal
Sony Handycam HDR-CX675 Shutter Assembly Replacement
O que você precisa
  1. Sony Handycam HDR-CX675 Shutter Assembly Replacement, Camera Shell: passo 1, imagem 1 %32
    • The battery should be removed and oriented upwards.
  2. Sony Handycam HDR-CX675 Shutter Assembly Replacement: passo 2, imagem 1 %32
    • Remove the side 4.5 mm JIS #00 screw using JIS Screwdriver
    • Remove the 5.5 mm JIS #00 screw.
  3. Sony Handycam HDR-CX675 Shutter Assembly Replacement: passo 3, imagem 1 %32 Sony Handycam HDR-CX675 Shutter Assembly Replacement: passo 3, imagem 2 %32
    • Gently pry the plastic case surrounding the start/stop button free by using the blue plastic opening tools.
    • Remove the casing using your thumb and index finger.
  4. Sony Handycam HDR-CX675 Shutter Assembly Replacement: passo 4, imagem 1 %32
    • Turn the camera around and flip open the LCD screen to expose the side panel.
    • Remove the 5.5mm #00 screw using the J00 head screwdriver.
  5. Sony Handycam HDR-CX675 Shutter Assembly Replacement: passo 5, imagem 1 %32
    • Turn the camera to the handgrip side and unscrew two of the 5.5mm JIS #00 head screws using the JIS #00 head screwdriver.
  6. Sony Handycam HDR-CX675 Shutter Assembly Replacement: passo 6, imagem 1 %32
    • Remove the two 5.5mm JIS #00 screws with the bottom of the camera facing up.
  7. Sony Handycam HDR-CX675 Shutter Assembly Replacement: passo 7, imagem 1 %32
    • Turn the camera around in a way that the bottom of the camera is facing you.
    • Use the blue opening tool to gently remove the camera shell off of the camera.
  8. Sony Handycam HDR-CX675 Shutter Assembly Replacement, Lens Cover Panel: passo 8, imagem 1 %32
    • Using the blue plastic opener smoothly to take the camera shell off.
  9. Sony Handycam HDR-CX675 Shutter Assembly Replacement: passo 9, imagem 1 %32 Sony Handycam HDR-CX675 Shutter Assembly Replacement: passo 9, imagem 2 %32
    • Let the lens of the camera be pointed to your left.
    • Keep holding the camera with your right hand then gently remove the lens cover panel with your left hand.
  10. Sony Handycam HDR-CX675 Shutter Assembly Replacement, Shutter Assembly: passo 10, imagem 1 %32
    • Place the camera on its lens and keep the LCD screen open and pointed to your right.
    • Remove the 5.5mm JIS #00 screws from the hinge of the camera.
  11. Sony Handycam HDR-CX675 Shutter Assembly Replacement: passo 11, imagem 1 %32 Sony Handycam HDR-CX675 Shutter Assembly Replacement: passo 11, imagem 2 %32
    • Hold the camera with your left hand, and gently remove the shutter assembly part.
  12. Sony Handycam HDR-CX675 Shutter Assembly Replacement: passo 12, imagem 1 %32
    Ferramenta utilizada neste passo:
    • Hold the camera that the bottom is upwards and lens pointed to your left hand.
    • By the metal tweezers, remove the white wire that is connecting the shutter assembly and motherboard
Conclusão
Uma outra pessoa concluiu este guia.
Mohamed Nazer
Membro desde: 02/15/17
403 Reputação
Autoria de 3 guias
Equipe
USF Tampa, Team 8-2, Eyestone Spring 2017 Membro de USF Tampa, Team 8-2, Eyestone Spring 2017
USFT-EYESTONE-S17S8G2
Membros da 3
Autoria de 8 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 11
Duração total: 849
