Ir para o conteúdo principal
Sony Handycam HDR-CX380 Camera Shell Replacement
O que você precisa
  1. Sony Handycam HDR-CX380 Camera Shell Replacement, Battery: passo 1, imagem 1 %32
    • Rotate your camera such that the underside is facing you and the lens is facing the ground.
    • You should be able to see the camera's label, and it should be rotated 90 degrees counterclockwise.
  2. Sony Handycam HDR-CX380 Camera Shell Replacement: passo 2, imagem 1 %32
    • Using your left thumb, push down the slider to the left of the SD card slot.
    • When inserting a new battery or reinserting the one you removed, you can ignore this step.
  3. Sony Handycam HDR-CX380 Camera Shell Replacement: passo 3, imagem 1 %32 Sony Handycam HDR-CX380 Camera Shell Replacement: passo 3, imagem 2 %32
    • Using your right index finger and thumb, pull the battery toward you and then away from the camera.
  4. Sony Handycam HDR-CX380 Camera Shell Replacement, Camera Shell: passo 4, imagem 1 %32
    • Orient the camera with the battery side facing up.
  5. Sony Handycam HDR-CX380 Camera Shell Replacement: passo 5, imagem 1 %32
    • Remove the single 4.5 mm Phillips #00 screw.
    • Remove the single 5.5 mm Phillips #00 screw.
  6. Sony Handycam HDR-CX380 Camera Shell Replacement: passo 6, imagem 1 %32 Sony Handycam HDR-CX380 Camera Shell Replacement: passo 6, imagem 2 %32
    • With the blue plastic opening tools, gently pry the plastic casing surrounding the start/stop button free.
    • Remove the casing using your right thumb and index finger.
  7. Sony Handycam HDR-CX380 Camera Shell Replacement: passo 7, imagem 1 %32
    • Flip open the LCD panel to get to the side panel.
    • Remove the three 5.5 mm Phillips #00 screws.
  8. Sony Handycam HDR-CX380 Camera Shell Replacement: passo 8, imagem 1 %32
    • Turn the camera around to the grip side and remove the 5.5 mm Phillips Head screw using your J00 Phillips Head screwdriver.
  9. Sony Handycam HDR-CX380 Camera Shell Replacement: passo 9, imagem 1 %32
    • With the bottom of the camera facing up, remove the two 5.5mm Phillips #00 screws.
  10. Sony Handycam HDR-CX380 Camera Shell Replacement: passo 10, imagem 1 %32 Sony Handycam HDR-CX380 Camera Shell Replacement: passo 10, imagem 2 %32
    • Orient the camera so the bottom is facing you.
    • Use the blue plastic opening tools to gently ease the camera shell off of the camera.
    • Rotate the camera so the LCD side panel is facing you and gently pry the shell off from the camera.
Conclusão
Uma outra pessoa concluiu este guia.
Zackary Williams
Membro desde: 02/04/16
457 Reputação
Autoria de 3 guias
Equipe
USF Tampa, Team 16-5, Blackwell Winter 2016 Membro de USF Tampa, Team 16-5, Blackwell Winter 2016
USFT-BLACKWELL-W16S16G5
Membros da 3
Autoria de 16 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 8
Duração total: 296
