Ir para o conteúdo principal
Sony Handycam HDR-CX380 Battery Replacement
  1. Sony Handycam HDR-CX380 Battery Replacement, Battery: passo 1, imagem 1 %32
    • Rotate your camera such that the underside is facing you and the lens is facing the ground.
    • You should be able to see the camera's label, and it should be rotated 90 degrees counterclockwise.
  2. Sony Handycam HDR-CX380 Battery Replacement: passo 2, imagem 1 %32
    • Using your left thumb, push down the slider to the left of the SD card slot.
    • When inserting a new battery or reinserting the one you removed, you can ignore this step.
  3. Sony Handycam HDR-CX380 Battery Replacement: passo 3, imagem 1 %32 Sony Handycam HDR-CX380 Battery Replacement: passo 3, imagem 2 %32
    • Using your right index finger and thumb, pull the battery toward you and then away from the camera.
Conclusão
To insert a new battery or reinsert the one you removed, simply follow step 3 in reverse order and rotate the camera as described in step 1.
Uma outra pessoa concluiu este guia.
John Santoro
Membro desde: 02/04/16
729 Reputação
Autoria de 5 guias
Equipe
USF Tampa, Team 16-5, Blackwell Winter 2016 Membro de USF Tampa, Team 16-5, Blackwell Winter 2016
USFT-BLACKWELL-W16S16G5
Membros da 3
Autoria de 16 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 12
Duração total: 561
