Ir para o conteúdo principal
Sony Handycam HDR­-CX220 Display Screen Replacement
O que você precisa
  1. Sony Handycam HDR­-CX220 Display Screen Replacement, Battery: passo 1, imagem 1 %32
    • Push in the battery indicator.
  2. Sony Handycam HDR­-CX220 Display Screen Replacement: passo 2, imagem 1 %32
    • Slide the battery out of the slot.
    • To put the battery back in, line up the battery's metal part with the camera's and slide it in.
  3. Sony Handycam HDR­-CX220 Display Screen Replacement, Camera's Body: passo 3, imagem 1 %32 Sony Handycam HDR­-CX220 Display Screen Replacement, Camera's Body: passo 3, imagem 2 %32 Sony Handycam HDR­-CX220 Display Screen Replacement, Camera's Body: passo 3, imagem 3 %32
    • Use the Phillips #0 screwdriver to remove the two 5mm screws.
    • Use the Phillips #0 screwdriver to remove the three 5mm screws.
  4. Sony Handycam HDR­-CX220 Display Screen Replacement: passo 4, imagem 1 %32 Sony Handycam HDR­-CX220 Display Screen Replacement: passo 4, imagem 2 %32 Sony Handycam HDR­-CX220 Display Screen Replacement: passo 4, imagem 3 %32
    • Use the plastic opening tool to loosen the plastic case of the camcorder.
  5. Sony Handycam HDR­-CX220 Display Screen Replacement: passo 5, imagem 1 %32
    • Use your hands to remove the plastic case.
    • Gently pull on the case not to damage anything internally.
  6. Sony Handycam HDR­-CX220 Display Screen Replacement, Display Screen: passo 6, imagem 1 %32 Sony Handycam HDR­-CX220 Display Screen Replacement, Display Screen: passo 6, imagem 2 %32
    • Use the Phillips #0 screwdriver to remover the two (5mm) screws on the outer part and one (3mm) in the middle.
    • In the second image, there is a second screw on the opposite side of the screen hinge. This screw is not shown, but must also be removed.
  7. Sony Handycam HDR­-CX220 Display Screen Replacement: passo 7, imagem 1 %32
    • Use the plastic opening tool to remove the plastic case protecting the screen
    • Pull it gently not to damage anything under the case
  8. Sony Handycam HDR­-CX220 Display Screen Replacement: passo 8, imagem 1 %32 Sony Handycam HDR­-CX220 Display Screen Replacement: passo 8, imagem 2 %32
    • Use the Phillips #0 screwdriver to remove the 2 screws shown
    • Use your hands to carefully unhook the screen from the highlighted hook
  9. Sony Handycam HDR­-CX220 Display Screen Replacement: passo 9, imagem 1 %32 Sony Handycam HDR­-CX220 Display Screen Replacement: passo 9, imagem 2 %32 Sony Handycam HDR­-CX220 Display Screen Replacement: passo 9, imagem 3 %32
    • Use your hands to carefully remove the tape
    • After removing the tape, pull on the wire disconnecting it from the screen.
Conclusão
4 outras pessoas executaram este guia.
Keven
Membro desde: 03/11/16
811 Reputação
Autoria de 6 guias
Equipe
UMass Dartmouth, Team 8-5, Botvin Spring 2016 Membro de UMass Dartmouth, Team 8-5, Botvin Spring 2016
UMASSD-BOTVIN-S16S8G5
3 Membros
Autoria de 12 guias
3 comentários
How do you mount hdr cx220 lcd cable flat? can you help me?
Rafael Oliveira - Responder
gjhgvnvyh n hygfv
ANM WORLD - Responder
We have a camera 220. Whose dipstick display strip has deteriorated again. Where can I find this strip? Video is good information so that's why
Comentar
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 6
Últimos 30 dias: 29
Ao todo: 2,675
