Introdução
The replacement of the screen is needed if the image on the screen is not the desired image or if the screen is physically damaged.
O que você precisa
Use the Phillips #0 screwdriver to remove the two 5mm screws.
Use the Phillips #0 screwdriver to remove the three 5mm screws.
Use the Phillips #0 screwdriver to remover the two (5mm) screws on the outer part and one (3mm) in the middle.
In the second image, there is a second screw on the opposite side of the screen hinge. This screw is not shown, but must also be removed.
4 outras pessoas executaram este guia.
3Comentários do guia
How do you mount hdr cx220 lcd cable flat? can you help me?
