Ir para o conteúdo principal
Sony Handycam HDR­-CX220 Buttons Replacement
O que você precisa
  1. Sony Handycam HDR­-CX220 Buttons  Replacement, Battery: passo 1, imagem 1 %32
    • Push in the battery indicator.
  2. Sony Handycam HDR­-CX220 Buttons  Replacement: passo 2, imagem 1 %32
    • Slide the battery out of the slot.
    • To put the battery back in, line up the battery's metal part with the camera's and slide it in.
  3. Sony Handycam HDR­-CX220 Buttons  Replacement, Camera's Body: passo 3, imagem 1 %32 Sony Handycam HDR­-CX220 Buttons  Replacement, Camera's Body: passo 3, imagem 2 %32 Sony Handycam HDR­-CX220 Buttons  Replacement, Camera's Body: passo 3, imagem 3 %32
    • Use the Phillips #0 screwdriver to remove the two 5mm screws.
    • Use the Phillips #0 screwdriver to remove the three 5mm screws.
  4. Sony Handycam HDR­-CX220 Buttons  Replacement: passo 4, imagem 1 %32 Sony Handycam HDR­-CX220 Buttons  Replacement: passo 4, imagem 2 %32 Sony Handycam HDR­-CX220 Buttons  Replacement: passo 4, imagem 3 %32
    • Use the plastic opening tool to loosen the plastic case of the camcorder.
  5. Sony Handycam HDR­-CX220 Buttons  Replacement: passo 5, imagem 1 %32
    • Use your hands to remove the plastic case.
    • Gently pull on the case not to damage anything internally.
  6. Sony Handycam HDR­-CX220 Buttons  Replacement, Buttons: passo 6, imagem 1 %32 Sony Handycam HDR­-CX220 Buttons  Replacement, Buttons: passo 6, imagem 2 %32 Sony Handycam HDR­-CX220 Buttons  Replacement, Buttons: passo 6, imagem 3 %32
    • Use the Philips #0 screwdriver to unscrew the two 5mm screws shown on top of the camera.
    • Remove the one side 5mm screw using a Philips #0 Screwdriver.
    • Remove the top buttons from the hook.
  7. Sony Handycam HDR­-CX220 Buttons  Replacement: passo 7, imagem 1 %32 Sony Handycam HDR­-CX220 Buttons  Replacement: passo 7, imagem 2 %32
    • Unplug the connected wire shown.
    • Pull gently not to cause any damage.
Conclusão
Keven
Membro desde: 03/11/16
811 Reputação
Autoria de 6 guias
Equipe
UMass Dartmouth, Team 8-5, Botvin Spring 2016 Membro de UMass Dartmouth, Team 8-5, Botvin Spring 2016
UMASSD-BOTVIN-S16S8G5
3 Membros
Autoria de 12 guias
1Comentário do guia
hi, can you please tell me where can I buyStep 6 Buttons?
thanks
jesus - Responder
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 7
Ao todo: 958
