Ir para o conteúdo principal
Sony Handycam DCR-SR42 Lens Replacement
O que você precisa
  1. Sony Handycam DCR-SR42 Lens Replacement, Hard Drive: passo 1, imagem 1 %32 Sony Handycam DCR-SR42 Lens Replacement, Hard Drive: passo 1, imagem 2 %32
    • Remove the battery, and use the Phillips #00 precision screwdriver to then remove the three 3mm Phillips #00 screws under the battery.
    • Wait 1 hour after removing the battery before continuing to disassemble the camera.
  2. Sony Handycam DCR-SR42 Lens Replacement: passo 2, imagem 1 %32
    • Remove the three 3mm #00 Phillips screws on the bottom of the camera.
  3. Sony Handycam DCR-SR42 Lens Replacement: passo 3, imagem 1 %32
    • Remove the three 3mm Phillips #00 screws on the side of the camera.
    • Remove the 4mm Phillips #00 screw under the AV port cover.
  4. Sony Handycam DCR-SR42 Lens Replacement: passo 4, imagem 1 %32 Sony Handycam DCR-SR42 Lens Replacement: passo 4, imagem 2 %32
    • Gently pull the black plastic hard drive cover away from the body of the camera. This will expose the hard drive.
    • Even with all the screws removed, this part will require some force to remove.
  5. Sony Handycam DCR-SR42 Lens Replacement: passo 5, imagem 1 %32 Sony Handycam DCR-SR42 Lens Replacement: passo 5, imagem 2 %32
    • Lift the hard drive out of the camera by grasping the grey rubber mounting brackets and pulling them upwards.
    • The hard drive is attached to the flex cable. Remove the hard drive slowly to prevent the flex cable from being damaged.
  6. Sony Handycam DCR-SR42 Lens Replacement: passo 6, imagem 1 %32
    • Remove the rubber mounting brackets by pulling them off the hard drive.
  7. Sony Handycam DCR-SR42 Lens Replacement: passo 7, imagem 1 %32
    • Carefully unplug the flex cable from the hard drive.
  8. Sony Handycam DCR-SR42 Lens Replacement, Internal Components: passo 8, imagem 1 %32 Sony Handycam DCR-SR42 Lens Replacement, Internal Components: passo 8, imagem 2 %32
    • Remove the four 3mm Phillips #00 screws from under the hard drive.
  9. Sony Handycam DCR-SR42 Lens Replacement: passo 9, imagem 1 %32 Sony Handycam DCR-SR42 Lens Replacement: passo 9, imagem 2 %32 Sony Handycam DCR-SR42 Lens Replacement: passo 9, imagem 3 %32
    • Press in on the two tabs as shown and lift the metal plate up and off the camera.
  10. Sony Handycam DCR-SR42 Lens Replacement: passo 10, imagem 1 %32 Sony Handycam DCR-SR42 Lens Replacement: passo 10, imagem 2 %32 Sony Handycam DCR-SR42 Lens Replacement: passo 10, imagem 3 %32
    • Remove the two 4mm Phillips #00 screws from the underside of the camera.
    • Remove the 2 mm Phillips #00 screw from the screen hinge.
    • Remove the two 6mm Philips #00 screws from the side
  11. Sony Handycam DCR-SR42 Lens Replacement: passo 11, imagem 1 %32 Sony Handycam DCR-SR42 Lens Replacement: passo 11, imagem 2 %32 Sony Handycam DCR-SR42 Lens Replacement: passo 11, imagem 3 %32
    • Use the plastic opening tool to remove the plastic cover from the top of the camera.
    • Remove the two 3mm Phillips #00 screws from underneath the plastic cover.
  12. Sony Handycam DCR-SR42 Lens Replacement: passo 12, imagem 1 %32 Sony Handycam DCR-SR42 Lens Replacement: passo 12, imagem 2 %32
    • Remove the second plastic cover from the top of the camera.
    • Remove the 4mm Phillips #00 screw from underneath the cover.
  13. Sony Handycam DCR-SR42 Lens Replacement: passo 13, imagem 1 %32 Sony Handycam DCR-SR42 Lens Replacement: passo 13, imagem 2 %32
    • Carefully pry the screen assembly apart from the main body of the camera.
    • Unplug the flex cable from the screen assembly.
  14. Sony Handycam DCR-SR42 Lens Replacement, Lens: passo 14, imagem 1 %32
    • Remove the 3mm Phillips #00 screw from the underside of the camera near the lens housing.
  15. Sony Handycam DCR-SR42 Lens Replacement: passo 15, imagem 1 %32 Sony Handycam DCR-SR42 Lens Replacement: passo 15, imagem 2 %32
    • Use the plastic opening tool to pry the side casing off the camera.
  16. Sony Handycam DCR-SR42 Lens Replacement: passo 16, imagem 1 %32
    • Remove the final 3mm #00 Phillips screw from the lens housing.
  17. Sony Handycam DCR-SR42 Lens Replacement: passo 17, imagem 1 %32
    • Remove the lens housing from the camera.
  18. Sony Handycam DCR-SR42 Lens Replacement: passo 18, imagem 1 %32
    • Remove the three 2mm Phillips #00 screws from around the lens.
  19. Sony Handycam DCR-SR42 Lens Replacement: passo 19, imagem 1 %32
    • Remove the lens from the camera.
Conclusão
Uma outra pessoa concluiu este guia.
Dan Muller
Membro desde: 03/23/15
1.020 Reputação
Autoria de 5 guias
Equipe
Baylor, Team 7-13, Williams Spring 2015 Membro de Baylor, Team 7-13, Williams Spring 2015
BU-WILLIAMS-S15S7G13
Membros da 4
Autoria de 10 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 24
Duração total: 759
