Introdução
Use this repair guide to remove and replace the Sony Handycam DCR DVD103 lens. Removing and replacing the lens provide repair access to other camera components, such as the battery and outer cover.
If the Sony Handycam DCR DVD103 has a cracked or broken lens, this repair guide will help the camera perform as designed. This repair does not require special skills.
The camera featured in this repair guide does not contain a battery.
Ferramentas
Peças
Nenhum componente especificado.
On the back of the camera beneath the viewfinder, locate the battery pack.
Press the small button that is marked with the red circle, then slide the switch (marked with the yellow rectangle) forward.
Using a #00 Philips screwdriver, remove the six 4.5 mm screws from the camera's bottom.
Uma outra pessoa concluiu este guia.
