Introdução
Occasionally, the laser eye will break or no longer move along the track. In this handycam, the laser eye is not replaceable by itself, but the laser bay may be swapped.
Ferramentas
Peças
Nenhum componente especificado.
On the back of the camera beneath the viewfinder, locate the battery pack.
Press the small button that is marked with the red circle, then slide the switch (marked with the yellow rectangle) forward.
Using a #00 Philips screwdriver, remove the six 4.5 mm screws from the camera's bottom.
Remove (1) 2.9mm screw from under the eye piece.
Remove (1) 2.9mm screw from above the eye piece.
Remove (4) copper strips from bellow the eye piece.
Pull off the eye piece assembly.
