Introdução
This guide will teach you how to replace the battery port on your Sony Handycam CX260V.
O que você precisa
Remove the 3 mm screw and two 5 mm screws using a Phillips #00 screwdriver from the battery assembly area.
Unplug the battery port connected to the frame/motherboard. Remove the battery port.
4 outras pessoas executaram este guia.
