Ir para o conteúdo principal
Sony HDR-AS30V LCD Screen Replacement
O que você precisa
  1. Sony HDR-AS30V LCD Screen Replacement, Outer Casing: passo 1, imagem 1 %32
    • Power off the device. Remove the component jack cover.
    • Open component door.
    • Using the Phillips 00 screwdriver, remove the two screws holding the jack cover in place.
  2. Sony HDR-AS30V LCD Screen Replacement: passo 2, imagem 1 %32
    • Open the battery door.
    • Slide the battery cap along the length of the camera, then flip the cap outward. Use caution; there may be internal damage affecting the functionality of the sliding mechanism.
  3. Sony HDR-AS30V LCD Screen Replacement: passo 3, imagem 1 %32
    • Prepare to remove outer casing.
    • Using the 2.5 mm precision slotted screwdriver, insert the tip of the screwdriver under the holder to wedge. Use caution when preparing to wedge apart fragile components.
  4. Sony HDR-AS30V LCD Screen Replacement: passo 4, imagem 1 %32
    • Separate Casing from Device.
    • With the screwdriver wedged, apply slight force while pulling the casing away from the device. Use caution to avoid causing damage to fragile parts.
  5. Sony HDR-AS30V LCD Screen Replacement: passo 5, imagem 1 %32
    • With the outer casing pulled away from the device, take note of the orientation of the inner component to avoid an electrical short.
    • Once the orientation of the inner component is noted, slide the inner component out of the casing. You may now replace the broken casing with a new one.
  6. Sony HDR-AS30V LCD Screen Replacement, LCD Screen: passo 6, imagem 1 %32
    • Remove two screws with the PH000 screwdriver.
    • Pop off plastic holder.
  7. Sony HDR-AS30V LCD Screen Replacement: passo 7, imagem 1 %32
    • With the flathead screwdriver, wedge under area shown and pop upwards.
    • Be sure to move the flex cable out of the way while flipping the plastic inner casing upward.
  8. Sony HDR-AS30V LCD Screen Replacement: passo 8, imagem 1 %32
    • Gently push speaker out of slot
  9. Sony HDR-AS30V LCD Screen Replacement: passo 9, imagem 1 %32
    • Flip open screen and make sure no cables are in the way.
  10. Sony HDR-AS30V LCD Screen Replacement: passo 10, imagem 1 %32
    • With the flathead, lift up cable lock and pull the film out from underneath the lock.
  11. Sony HDR-AS30V LCD Screen Replacement: passo 11, imagem 1 %32
    • Gently pull out screen.
Conclusão
Dylan Keiter
Membro desde: 01/28/15
101 Reputação
Autoria de 1 guia
Equipe
Penn State, Team 2-12, Kaschak Winter 2015 Membro de Penn State, Team 2-12, Kaschak Winter 2015
PSU-KASCHAK-W15S2G12
Membros da 4
Autoria de 4 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 5
Duração total: 504
