Ir para o conteúdo principal
Sony Ericsson z300 Vibrator Replacement
O que você precisa
  1. Sony Ericsson z300 Vibrator Replacement, Back Phone Cover: passo 1, imagem 1 %32
    • To remove the back cover, use your thumb to press down on the center of case and slide it off.
  2. Sony Ericsson z300 Vibrator Replacement, Battery: passo 2, imagem 1 %32
    • Using a fingernail lift the battery out of the phone.
  3. Sony Ericsson z300 Vibrator Replacement, Front Phone Cover: passo 3, imagem 1 %32
    • To remove the front cover, lift up the case with a fingernail in the small slot as shown.
  4. Sony Ericsson z300 Vibrator Replacement, Front Dark Grey Case: passo 4, imagem 1 %32
    • To remove the front grey case, remove the two screws shown with a T5 Torx Screwdriver.
  5. Sony Ericsson z300 Vibrator Replacement: passo 5, imagem 1 %32
    • Pry up the dark grey case with your fingernail until all four snaps around the top are loose.
  6. Sony Ericsson z300 Vibrator Replacement: passo 6, imagem 1 %32
    • Lift up towards the bottom and slide the case off.
  7. Sony Ericsson z300 Vibrator Replacement, Screens: passo 7, imagem 1 %32
    • Use a plastic opening tool to lift the black tape off of the ribbon cable connector.
  8. Sony Ericsson z300 Vibrator Replacement: passo 8, imagem 1 %32
    • Lift the ribbon cable connector lock using a plastic opening tool.
  9. Sony Ericsson z300 Vibrator Replacement: passo 9, imagem 1 %32 Sony Ericsson z300 Vibrator Replacement: passo 9, imagem 2 %32
    • Slide the black ribbon cable tray out with a plastic opening tool.
    • Shown in the second picture is the try already slid out.
  10. Sony Ericsson z300 Vibrator Replacement: passo 10, imagem 1 %32 Sony Ericsson z300 Vibrator Replacement: passo 10, imagem 2 %32
    • Slide the ribbon cable out of the connector.
    • Shown in the second picture is the cable already out.
  11. Sony Ericsson z300 Vibrator Replacement: passo 11, imagem 1 %32
    • Use a plastic opening tool to lift up on the screen board and release the clips holding it in place.
    • Lift the entire board out of the phone to remove both screens.
  12. Sony Ericsson z300 Vibrator Replacement, Vibrator: passo 12, imagem 1 %32
    • Use a plastic opening tool to lift the vibrator out of its slot.
Conclusão
Alex Serventi
Membro desde: 10/07/10
65 Reputação
Autoria de 13 guias
Equipe
Cal Poly, Team 5-15, Maness Fall 2010 Membro de Cal Poly, Team 5-15, Maness Fall 2010
CPSU-MANESS-F10S5G15
Membros da 4
Autoria de 26 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 3
Duração total: 2,146
