Ir para o conteúdo principal
Sony Ericsson z300 Keypad Replacement
O que você precisa
  1. Sony Ericsson z300 Keypad Replacement, Back Phone Cover: passo 1, imagem 1 %32
    • To remove the back cover, use your thumb to press down on the center of case and slide it off.
  2. Sony Ericsson z300 Keypad Replacement, Battery: passo 2, imagem 1 %32
    • Using a fingernail lift the battery out of the phone.
  3. Sony Ericsson z300 Keypad Replacement, Sim Card: passo 3, imagem 1 %32
    • Slide the sim card out with your thumb.
  4. Sony Ericsson z300 Keypad Replacement, Back Dark Grey Case: passo 4, imagem 1 %32
    • To remove the back case first remove the four screws shown with a T5 Torx screwdriver
  5. Sony Ericsson z300 Keypad Replacement: passo 5, imagem 1 %32
    • Using your fingernail lift up the side of the casing around the bottom of the phone to release all five of the clips.
  6. Sony Ericsson z300 Keypad Replacement: passo 6, imagem 1 %32
    • Lift up towards the bottom and slide the case off.
  7. Sony Ericsson z300 Keypad Replacement, Motherboard: passo 7, imagem 1 %32
    • Use a plastic opening tool to lift up the brass colored panel.
  8. Sony Ericsson z300 Keypad Replacement: passo 8, imagem 1 %32
    • Flip up the yellow tab using a plastic opening tool to disconnect the motherboard from the phone body.
  9. Sony Ericsson z300 Keypad Replacement: passo 9, imagem 1 %32
    • Work the plastic opening tool around the edges of the motherboard to release it from the clips.
  10. Sony Ericsson z300 Keypad Replacement, Keypad: passo 10, imagem 1 %32
    • Using a plastic opening tool lift up the keypad to remove it.
Conclusão
Uma outra pessoa concluiu este guia.
Alex Serventi
Membro desde: 10/07/10
65 Reputação
Autoria de 13 guias
Equipe
Cal Poly, Team 5-15, Maness Fall 2010 Membro de Cal Poly, Team 5-15, Maness Fall 2010
CPSU-MANESS-F10S5G15
Membros da 4
Autoria de 26 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Duração total: 1,335
