Introdução
This guide will show you how to remove the Dark Grey case that allows you access to the Screens.
Peças
Não são necessárias peças.
  1. To remove the front cover, lift up the case with a fingernail in the small slot as shown.
    • To remove the front cover, lift up the case with a fingernail in the small slot as shown.
  2. To remove the front grey case, remove the two screws shown with a T5 Torx Screwdriver.
    • To remove the front grey case, remove the two screws shown with a T5 Torx Screwdriver.
  3. Free shipping on all orders over US$100,00 or containing a Pro Tech Toolkit!
    Visite Nossa Loja
    Ever fixed something? That’s Genius.
    Share your repair story with #ImAGenius
    We Are All Geniuses
  4. Pry up the dark grey case with your fingernail until all four snaps around the top are loose.
    • Pry up the dark grey case with your fingernail until all four snaps around the top are loose.
  5. Lift up towards the bottom and slide the case off.
    • Lift up towards the bottom and slide the case off.
Conclusão
Uma outra pessoa concluiu este guia.
Alex Serventi
50 reputação
13 Guides authored
Equipe
Cal Poly, Team 5-15, Maness Fall 2010 Membro de Cal Poly, Team 5-15, Maness Fall 2010
CPSU-MANESS-F10S5G15
4 Membros
26 Guides authored
Visualizar Estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Todo: 1,031
