Ir para o conteúdo principal
Sony Ericsson xPeria Active Screen Replacement
O que você precisa
  1. Sony Ericsson xPeria Active Screen Replacement, Remove the back cover.: passo 1, imagem 1 %32 Sony Ericsson xPeria Active Screen Replacement, Remove the back cover.: passo 1, imagem 2 %32 Sony Ericsson xPeria Active Screen Replacement, Remove the back cover.: passo 1, imagem 3 %32
    • Open the flaps and remove the back cover using the plastic opening device.
  2. Sony Ericsson xPeria Active Screen Replacement, Remove inside plastic battery cover.: passo 2, imagem 1 %32 Sony Ericsson xPeria Active Screen Replacement, Remove inside plastic battery cover.: passo 2, imagem 2 %32
    • Remove the battery shield with the plastic opening device.
  3. Sony Ericsson xPeria Active Screen Replacement, Remove the battery: passo 3, imagem 1 %32 Sony Ericsson xPeria Active Screen Replacement, Remove the battery: passo 3, imagem 2 %32
    • Remove the battery.
  4. Sony Ericsson xPeria Active Screen Replacement, Unfastening The Motherboard Cover: passo 4, imagem 1 %32
    • Unscrew the 5mm screws with the T5 head.
    • Unscrew the 6mm screw with the T6 head.
  5. Sony Ericsson xPeria Active Screen Replacement, Removing The Motherboard Cover: passo 5, imagem 1 %32 Sony Ericsson xPeria Active Screen Replacement, Removing The Motherboard Cover: passo 5, imagem 2 %32
    • Remove the black cover with the plastic opening tool.
    • Remove the headphone jack from its slot.
  6. Sony Ericsson xPeria Active Screen Replacement, Screen: passo 6, imagem 1 %32 Sony Ericsson xPeria Active Screen Replacement, Screen: passo 6, imagem 2 %32
    • Unplug the power cable by carefully prying it away from the motherboard.
  7. Sony Ericsson xPeria Active Screen Replacement: passo 7, imagem 1 %32 Sony Ericsson xPeria Active Screen Replacement: passo 7, imagem 2 %32
    • Remove the power strip on the back side of the motherboard.
  8. Sony Ericsson xPeria Active Screen Replacement, Remove back screen shield: passo 8, imagem 1 %32 Sony Ericsson xPeria Active Screen Replacement, Remove back screen shield: passo 8, imagem 2 %32
    • Remove the shield.
  9. Sony Ericsson xPeria Active Screen Replacement, Remove the screen module: passo 9, imagem 1 %32 Sony Ericsson xPeria Active Screen Replacement, Remove the screen module: passo 9, imagem 2 %32
    • Push the screen through the front of the case, gently.
    • It may be a little tough, just work your way around the edges of the screen until it separates from the main case.
Conclusão
5 outras pessoas executaram este guia.
Alex Tobin
Membro desde: 10/06/14
406 Reputação
Autoria de 3 guias
Equipe
USF Tampa, Team 14-5, Leahy Fall 2014 Membro de USF Tampa, Team 14-5, Leahy Fall 2014
USFT-LEAHY-F14S14G5
Membros da 3
Autoria de 5 guias
Um comentário
hi can you add explain
abdnour master2 - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 18
Duração total: 2,357
