Introdução
The headphone jack will need to be replaced it it no longer outputs audio.
O que você precisa
Open the flaps and remove the back cover using the plastic opening device.
Remove the battery shield with the plastic opening device.
Unscrew the 5mm screws with the T5 head.
Unscrew the 6mm screw with the T6 head.
Remove the black cover with the plastic opening tool.
Remove the headphone jack from its slot.
3 outras pessoas executaram este guia.
