Ir para o conteúdo principal
Sony Ericsson Z500a Logic Board Replacement
O que você precisa
  1. Sony Ericsson Z500a Logic Board Replacement, Keypad: passo 1, imagem 1 %32 Sony Ericsson Z500a Logic Board Replacement, Keypad: passo 1, imagem 2 %32 Sony Ericsson Z500a Logic Board Replacement, Keypad: passo 1, imagem 3 %32
    • Remove the back cover by pulling it down, and then take out the battery.
    • Using a T6 Torx screwdriver, remove the 4 screws.
    • Keep the phone open with the back cover facing you.
  2. Sony Ericsson Z500a Logic Board Replacement: passo 2, imagem 1 %32
    • Use the plastic opening tool and run it between the case and the body of the device to loosen the keyboard
    • There are 2 clamps that lock the keyboard to the case (1 on each side)
  3. Sony Ericsson Z500a Logic Board Replacement: passo 3, imagem 1 %32
    • Flip the phone over and lift straight up on the key pad to remove it.
    • Be sure to hold the phone flat (parallel to the table) so that no loose parts fall out.
  4. Sony Ericsson Z500a Logic Board Replacement, Logic Board: passo 4, imagem 1 %32 Sony Ericsson Z500a Logic Board Replacement, Logic Board: passo 4, imagem 2 %32
    • Use the opening tool to remove the 2 ribbon wires (boxed in the photo) from the logic board.
    • Gently lift the back of the logic board and then pull outwards. Be careful not to rip the ribbon wire.
  5. Sony Ericsson Z500a Logic Board Replacement: passo 5, imagem 1 %32 Sony Ericsson Z500a Logic Board Replacement: passo 5, imagem 2 %32
    • Remove the black sim card reader and green vibrator before continuing to ensure they do not fall out.
Conclusão
Tim
Membro desde: 04/20/10
15 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team 7-12, Maness Spring 2010 Membro de Cal Poly, Team 7-12, Maness Spring 2010
CPSU-MANESS-S10S7G12
Membros da 4
Autoria de 10 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 2
Duração total: 1,652
