Esta versão pode conter edições incorretas. Mude para o último instantâneo verificado.
O que você precisa
Este passo não foi traduzido. Ajude a traduzi-lo
Remove the eight 5mm T6 screws from the back of the phone.
Use a case opening tool to release clips holding the case together.
Take the part on the left side and put it out of the way.
Insert a flat head screw driver under the two clips and pry up.
Using a flat head screwdriver, flip the chip to the left and remove the ribbon cable.
Remove the volume and camera buttons. Using your fingers or a screwdriver, pull off the black plastic piece on the very top of the phone.
Using a flat head screw driver, undo the ribbon cables connected to the phone.
Gently insert a flat head screw driver under the logic board and pry to remove it from the phone casing.
Using a flat head screw driver, disconnect the glue holding the left ribbon cable to the phone. Pull up the black plastic piece being pointed to in the image.
Using a flat head screwdriver, pry up the board.
Remove the power button from the top of the phone.
