Ir para o conteúdo principal
Sony Ericsson Xperia X10 Logic Board Replacement
O que você precisa
Vídeo de Apresentação
  1. Sony Ericsson Xperia X10 Logic Board Replacement, Logic Board: passo 1, imagem 1 %32 Sony Ericsson Xperia X10 Logic Board Replacement, Logic Board: passo 1, imagem 2 %32 Sony Ericsson Xperia X10 Logic Board Replacement, Logic Board: passo 1, imagem 3 %32
    • Switch-off the phone.
    • Remove the battery.
    • Unscrew 8x T6 Torx screws.
  2. Sony Ericsson Xperia X10 Logic Board Replacement: passo 2, imagem 1 %32 Sony Ericsson Xperia X10 Logic Board Replacement: passo 2, imagem 2 %32 Sony Ericsson Xperia X10 Logic Board Replacement: passo 2, imagem 3 %32
    • Use a Plastic Pry or other plastic tool to unhook the back housing / bezel and remove it.
    • Tip - try prying it open from the top and over to the side. It can be very tight if you are doing this for the first time. The volume rocker and camera button are not part of the housing, so try going around it.
  3. Sony Ericsson Xperia X10 Logic Board Replacement: passo 3, imagem 1 %32 Sony Ericsson Xperia X10 Logic Board Replacement: passo 3, imagem 2 %32 Sony Ericsson Xperia X10 Logic Board Replacement: passo 3, imagem 3 %32
    • Remove the Volume Up/Down and Camera buttons.
    • Unhook the SIM & SD Card reader unit and disconnect the flex cable.
  4. Sony Ericsson Xperia X10 Logic Board Replacement: passo 4, imagem 1 %32 Sony Ericsson Xperia X10 Logic Board Replacement: passo 4, imagem 2 %32 Sony Ericsson Xperia X10 Logic Board Replacement: passo 4, imagem 3 %32
    • Remove the Audio jack connector.
    • Disconnect 4x flex cables:
    • LCD Display
    • Menu buttons
    • Touchscreen
    • Earpiece, Volume & Power On buttons
    • Carefully remove the mother board.
    • Please SUBSCRIBE to my channel ツ
Conclusão
ZFix
Membro desde: 12/09/13
194.093 Reputação
Autoria de 330 guias
Equipe
Master Techs Membro de Master Techs
Community
327 Membros
Autoria de 1.699 guias
0 comentários
Comentar
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 6
Ao todo: 1,999
