Ir para o conteúdo principal
Sony Ericsson Xperia X10 Display Assembly Replacement
O que você precisa
  1. Sony Ericsson Xperia X10 Display Assembly Replacement, Display Assembly: passo 1, imagem 1 %32
    • Place the phone with the back facing up. Remove the back cover and the battery.
  2. Sony Ericsson Xperia X10 Display Assembly Replacement: passo 2, imagem 1 %32
    • Remove the 5mm screws from back of the phone, image indicates where they are. There should be 8 screws. Use a T-6 bit.
  3. Sony Ericsson Xperia X10 Display Assembly Replacement: passo 3, imagem 1 %32
    • Use a case opening tool to release clips holding together the case. It should be easier starting at the bottom right side of the phone, as indicated in the image. Insert the tool and run it down the side of the phone, using a prying motion to pull it apart.
  4. Sony Ericsson Xperia X10 Display Assembly Replacement: passo 4, imagem 1 %32
    • Case should be in two pieces. Take the side indicated in the left side of the image and put it out of the way.
  5. Sony Ericsson Xperia X10 Display Assembly Replacement: passo 5, imagem 1 %32
    • Insert a flat head screw driver under the two clips and pry up. The chip should come loose with just a ribbon cable holding it to the rest of the phone.
  6. Sony Ericsson Xperia X10 Display Assembly Replacement: passo 6, imagem 1 %32
    • Flip the chip to the left and remove the ribbon cable from the rest of the phone using a flat head screw driver. Gently insert the screw driver under the cable and pry up.
  7. Sony Ericsson Xperia X10 Display Assembly Replacement: passo 7, imagem 1 %32 Sony Ericsson Xperia X10 Display Assembly Replacement: passo 7, imagem 2 %32
    • If the volume rocker and camera button haven't fallen off yet, remove them and put them off to the side. Using your fingers or a screwdriver, pull off the black plastic piece on the very top of the phone. This is the audio jack.
  8. Sony Ericsson Xperia X10 Display Assembly Replacement: passo 8, imagem 1 %32
    • Using a flat head screw driver, undo the ribbon cables connected to the phone. There should be two on the left, one on the right, and one on the top.
  9. Sony Ericsson Xperia X10 Display Assembly Replacement: passo 9, imagem 1 %32
    • Gently insert a flat head screw driver under the logic board and pry to remove it from the phone casing. There should be a notch where a screw driver can fit as indicated in the image.
  10. Sony Ericsson Xperia X10 Display Assembly Replacement: passo 10, imagem 1 %32
    • Logic board should be removed from the phone. Put it off to the side.
  11. Sony Ericsson Xperia X10 Display Assembly Replacement: passo 11, imagem 1 %32 Sony Ericsson Xperia X10 Display Assembly Replacement: passo 11, imagem 2 %32
    • Using a flat head screw driver, disconnect the glue holding the left ribbon cable to the phone. Once unglued, the cable should flip back and still be connected to the phone. Pull up the black plastic piece being pointed to in the image.
  12. Sony Ericsson Xperia X10 Display Assembly Replacement: passo 12, imagem 1 %32 Sony Ericsson Xperia X10 Display Assembly Replacement: passo 12, imagem 2 %32
    • Using a flat head screwdriver, pry up the board. Should have to pry from the left and from the right. Nothing is holding in the power button on the top of the phone, go ahead and remove it.
    • The piece on the right side of the picture is the LCD screen. It appears that the speakers and other components are directly attached to the LCD and must be replace as one unit.
Conclusão
To reassemble your device, follow these instructions in reverse order. The pieces need to be placed exactly back into the phone as they came out or else they won't fit together correctly.
3 outras pessoas executaram este guia.
Matt
Membro desde: 10/29/13
319 Reputação
Autoria de 2 guias
Equipe
UMass Dartmouth, Team 1-5, Shastany Fall 2013 Membro de UMass Dartmouth, Team 1-5, Shastany Fall 2013
UMASSD-SHASTANY-F13S1G5
2 Membros
Autoria de 3 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 35
Ao todo: 4,066
