Introdução
Follow this guide to install a new power button in about 5 minutes.
O que você precisa
Locate the battery in your phone.
Find the divot below the battery.
Use your thumb to lift the battery out of the phone.
Remove the 4 black screws with the Phillips screwdriver.
Remove the 4 silver screws with the Torx screwdriver.
Insert the plastic opening tool in between the two halves of the case. Pry around the phone to detach the back case.
When the inner back cover is off, locate and remove the power button.
