Ir para o conteúdo principal
Sony Ericsson Xperia Play Touch Screen Glass Digitizer Replacement
O que você precisa
Vídeo de Apresentação
  1. Sony Ericsson Xperia Play Touch Screen Glass Digitizer Replacement, Touch Screen Glass Digitizer: passo 1, imagem 1 %32 Sony Ericsson Xperia Play Touch Screen Glass Digitizer Replacement, Touch Screen Glass Digitizer: passo 1, imagem 2 %32 Sony Ericsson Xperia Play Touch Screen Glass Digitizer Replacement, Touch Screen Glass Digitizer: passo 1, imagem 3 %32
    • Remove the battery cover and the battery.
    • Unscrew the 7x black screws and 6x silver screws.
    • Remove the rear bezel.
  2. Sony Ericsson Xperia Play Touch Screen Glass Digitizer Replacement: passo 2, imagem 1 %32 Sony Ericsson Xperia Play Touch Screen Glass Digitizer Replacement: passo 2, imagem 2 %32 Sony Ericsson Xperia Play Touch Screen Glass Digitizer Replacement: passo 2, imagem 3 %32
    • after removing the 2x black philips screws, use a plastic tool to disconnect the main flex cable connector.
    • Disconnect the gaming keyboard flex cable.
  3. Sony Ericsson Xperia Play Touch Screen Glass Digitizer Replacement: passo 3, imagem 1 %32 Sony Ericsson Xperia Play Touch Screen Glass Digitizer Replacement: passo 3, imagem 2 %32
    • Remove the motherboard and the gaming keyboard.
  4. Sony Ericsson Xperia Play Touch Screen Glass Digitizer Replacement: passo 4, imagem 1 %32 Sony Ericsson Xperia Play Touch Screen Glass Digitizer Replacement: passo 4, imagem 2 %32 Sony Ericsson Xperia Play Touch Screen Glass Digitizer Replacement: passo 4, imagem 3 %32
    • Remove the 4x philips screws and the small black sticker on the corner.
    • Disconnect the touchscreen flex cable connector.
    • Disassemble the front bezel.
  5. Sony Ericsson Xperia Play Touch Screen Glass Digitizer Replacement: passo 5, imagem 1 %32 Sony Ericsson Xperia Play Touch Screen Glass Digitizer Replacement: passo 5, imagem 2 %32 Sony Ericsson Xperia Play Touch Screen Glass Digitizer Replacement: passo 5, imagem 3 %32
    • To separate the touchscreen from the base bezel use hot air and plastic tools.
  6. Sony Ericsson Xperia Play Touch Screen Glass Digitizer Replacement: passo 6, imagem 1 %32 Sony Ericsson Xperia Play Touch Screen Glass Digitizer Replacement: passo 6, imagem 2 %32
    • Use double side adhesive tape to assemble the touch screen.
  7. Sony Ericsson Xperia Play Touch Screen Glass Digitizer Replacement: passo 7, imagem 1 %32
Conclusão
ZFix
Membro desde: 12/09/13
191.278 Reputação
Autoria de 330 guias
Equipe
Master Techs Membro de Master Techs
Community
Membros da 322
Autoria de 2.532 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 3
Últimos 30 dias: 18
Duração total: 3,209
