Ir para o conteúdo principal
Sony Ericsson Xperia Play Rear Facing Camera Replacement
O que você precisa
  1. Sony Ericsson Xperia Play Rear Facing Camera Replacement, Rear Facing Camera: passo 1, imagem 1 %32
    • Follow the Prerequisite Guide on how to Remove the Controller Plate/Buttons to prepare the phone for disassembly. Stop when the motherboard has been detached.
    • Orientate the motherboard so that the camera faces away, as shown in the picture.
  2. Sony Ericsson Xperia Play Rear Facing Camera Replacement: passo 2, imagem 1 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • With the camera facing away, pull it from the motherboard until it stands perpendicular to the board. Tweezers can be used to do this.
  3. Sony Ericsson Xperia Play Rear Facing Camera Replacement: passo 3, imagem 1 %32
    • Use tweezers to pull the camera off of the motherboard. Hold on to the plastic connector and apply the force away from the board.
  4. Sony Ericsson Xperia Play Rear Facing Camera Replacement: passo 4, imagem 1 %32
    • The camera is now detached.
Conclusão
Pieter Boersma
Membro desde: 03/25/15
371 Reputação
Autoria de 3 guias
Equipe
UMass Dartmouth, Team 7-3, Cichon Spring 2015 Membro de UMass Dartmouth, Team 7-3, Cichon Spring 2015
UMASSD-CICHON-S15S7G3
Membros da 3
Autoria de 3 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 10
Últimos 30 dias: 18
Duração total: 802
