Esta versão pode conter edições incorretas. Mude para o último instantâneo verificado.
O que você precisa
Este passo não foi traduzido. Ajude a traduzi-lo
Remove the battery cover and the battery.
You have 6x silver screw and 7x black screw and remove the rear bezel.
Now with a plastic tool disconnect the main flex cable. Be careful, near to the main flex cable connector there is many small elements.
Disconnect the gaming keyboard flex keyboard.
Unscrew the 4x screws.
Remove the black sticker.
Disconnect the touchscreen flex cable connector.
Now you can disassemble the front bezel.
Use the thin end of a plastic tool to remove LCD Display and disconnect the flex cable.
Now remove the small metal plate taped to the flex cable.
Remove the plastic plate from the back side of the flex cable connector.
Use the same technique when you are installing the new Main Ribbon Cable.
I prefer to test the new spare part before the full assembly.
5 outras pessoas executaram este guia.
3 comentários
Iv got a problem my phone won't turn on or charge but when i plug the charger in the power button just flashes red a couple of times then nothing do u know what this means is it the battery or the phone that is broke
