Ir para o conteúdo principal
Sony Ericsson Xperia Play Battery Replacement
O que você precisa
  1. Sony Ericsson Xperia Play Battery Replacement, Battery: passo 1, imagem 1 %32
    • Turn the phone around so the screen is facing a flat surface.
  2. Sony Ericsson Xperia Play Battery Replacement: passo 2, imagem 1 %32
    • To remove the cover, use plastic removal tool on the seam of the case.
    • Once enough force is applied, you should hear a “click” sound which indicates that cover is loose.
  3. Sony Ericsson Xperia Play Battery Replacement: passo 3, imagem 1 %32
    • After the “click” noise, lift the cover with your finger.
    • Do not puncture the battery. This can result in a fire.
  4. Sony Ericsson Xperia Play Battery Replacement: passo 4, imagem 1 %32
    • Proceed with removing the battery by lifting the battery with a small plastic pry tool.
    • Use a plastic tool for safety. If a plastic tool is not available use your fingers.
  5. Sony Ericsson Xperia Play Battery Replacement: passo 5, imagem 1 %32
    • Remove the battery from the device.
  6. Sony Ericsson Xperia Play Battery Replacement: passo 6, imagem 1 %32
    • Once the old battery id removed, slide the new battery, with the positive/negative indicator facing up, in so that the contacts of the battery make contact with the contacts of the phone.
  7. Sony Ericsson Xperia Play Battery Replacement: passo 7, imagem 1 %32
    • Lightly press the battery into the phone so that it is secure.
  8. Sony Ericsson Xperia Play Battery Replacement: passo 8, imagem 1 %32
    • To put the cover back on, apply force until a "click" sound is heard.
Conclusão
Pieter Boersma
Membro desde: 03/25/15
371 Reputação
Autoria de 3 guias
Equipe
UMass Dartmouth, Team 7-3, Cichon Spring 2015 Membro de UMass Dartmouth, Team 7-3, Cichon Spring 2015
UMASSD-CICHON-S15S7G3
Membros da 3
Autoria de 3 guias
Um comentário
Has ifixit thought about trying to make a replacement battery that would work with this? It would be good to be able to get the battery from here as well, even if it is potentially a niche market for these old phones.
waytodawn0 - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 24
Duração total: 1,551
