Ir para o conteúdo principal
Sony Ericsson W810I Logic Board Replacement
Guia arquivado
Este guia é mantido exclusivamente para fins históricos. Use a versão atualizada do guia para executar o reparo.
O que você precisa
  1. Sony Ericsson W810I Logic Board Replacement, Logic Board: passo 1, imagem 1 %32
    • Make sure the phone is off and press down firmly against the Cingular icon with your thumb
    • Slide the panel down and remove latch
  2. Sony Ericsson W810I Logic Board Replacement: passo 2, imagem 1 %32 Sony Ericsson W810I Logic Board Replacement: passo 2, imagem 2 %32
    • Lift and pull battery out
    • Remove the SIM card if you have one
  3. Sony Ericsson W810I Logic Board Replacement: passo 3, imagem 1 %32
    • Remove the two outer screws using a T-7 head for a screwdriver
  4. Sony Ericsson W810I Logic Board Replacement: passo 4, imagem 1 %32
    • Remove the two smaller inner screws with the Mini-Phillips screwdriver head
  5. Sony Ericsson W810I Logic Board Replacement: passo 5, imagem 1 %32 Sony Ericsson W810I Logic Board Replacement: passo 5, imagem 2 %32
    • Remove the Back (camera side) Faceplate with the blue hand-wedge
  6. Sony Ericsson W810I Logic Board Replacement: passo 6, imagem 1 %32 Sony Ericsson W810I Logic Board Replacement: passo 6, imagem 2 %32 Sony Ericsson W810I Logic Board Replacement: passo 6, imagem 3 %32
    • Flip the phone over and pry off the front (keypad side) faceplate with multiple blue hand-wedges
    • Separate keypad from logic board by turning it upside down and allowing it to fall off
  7. Sony Ericsson W810I Logic Board Replacement: passo 7, imagem 1 %32 Sony Ericsson W810I Logic Board Replacement: passo 7, imagem 2 %32
    • Remove the two remaining screws in the top corners of the phone using a T-6 screwdriver head
    • Remove the logic board with multiple blue hand-wedges, be careful not to snap the logic board in half, along with snapping the wiring from the logic board
Conclusão
Ben Micucci
Membro desde: 10/14/11
186 Reputação
Autoria de 5 guias
Equipe
James Madison, Team 2-2, Allen Fall 2011 Membro de James Madison, Team 2-2, Allen Fall 2011
JMU-ALLEN-F11S2G2
Membros da 2
Autoria de 10 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 11
Duração total: 1,622
