Ir para o conteúdo principal
Sony Ericsson W810I Camera Replacement
O que você precisa
  1. Sony Ericsson W810I Camera Replacement, Battery: passo 1, imagem 1 %32
    • Place your Sony Ericsson W810I screen side down with the battery cover facing up as shown.
    Pergunte ao FixBot
    Comentar
  2. Sony Ericsson W810I Camera Replacement: passo 2, imagem 1 %32
    • Remove the battery cover by applying downward pressure on the Singular Symbol and then shifting the pressure towards the bottom edge of the phone.
    Pergunte ao FixBot
    Comentar
  3. Sony Ericsson W810I Camera Replacement: passo 3, imagem 1 %32 Sony Ericsson W810I Camera Replacement: passo 3, imagem 2 %32
    • Lift the bottom of the battery away from the phone with your thumb and rotate until the opening in the bottom of the case is oriented downward. The battery should slide out.
    Pergunte ao FixBot
    Comentar
  4. Sony Ericsson W810I Camera Replacement, Case: passo 4, imagem 1 %32 Sony Ericsson W810I Camera Replacement, Case: passo 4, imagem 2 %32 Sony Ericsson W810I Camera Replacement, Case: passo 4, imagem 3 %32
    • Remove the two 3.9mm screws with a Phillips size #00 screwdriver.
    • Remove the two 6.35mm screws with a Torx T6 screwdriver.
    Pergunte ao FixBot
    Comentar
  5. Sony Ericsson W810I Camera Replacement: passo 5, imagem 1 %32 Sony Ericsson W810I Camera Replacement: passo 5, imagem 2 %32 Sony Ericsson W810I Camera Replacement: passo 5, imagem 3 %32
    • Run a plastic opening tool along the edge of the back casing while prying it apart to remove it.
    Pergunte ao FixBot
    Comentar
  6. Sony Ericsson W810I Camera Replacement: passo 6, imagem 1 %32 Sony Ericsson W810I Camera Replacement: passo 6, imagem 2 %32 Sony Ericsson W810I Camera Replacement: passo 6, imagem 3 %32
    • Turn the phone over and open the memory stick compartment.
    • Stick a plastic opening tools into the opening and twist it to gain some leverage. This should begin separating the front casing from the interior plastic support frame.
    Pergunte ao FixBot
    Comentar
  7. Sony Ericsson W810I Camera Replacement: passo 7, imagem 1 %32 Sony Ericsson W810I Camera Replacement: passo 7, imagem 2 %32 Sony Ericsson W810I Camera Replacement: passo 7, imagem 3 %32
    • Run the plastic opening tool upwards along that side, removing the housing.
    Pergunte ao FixBot
    Comentar
  8. Sony Ericsson W810I Camera Replacement, Key Pad: passo 8, imagem 1 %32 Sony Ericsson W810I Camera Replacement, Key Pad: passo 8, imagem 2 %32 Sony Ericsson W810I Camera Replacement, Key Pad: passo 8, imagem 3 %32
    • Peel the rubber keys away from their backing. Do not slide them off.
    • Set them aside.
    Pergunte ao FixBot
    Comentar
  9. Sony Ericsson W810I Camera Replacement: passo 9, imagem 1 %32 Sony Ericsson W810I Camera Replacement: passo 9, imagem 2 %32 Sony Ericsson W810I Camera Replacement: passo 9, imagem 3 %32
    • Insert a plastic opening tool under the left side of the keypad backing and start to lift.
    • Lift slowly, as you can damage the ribbon cable underneath if you pull the keypad backing away too forcefully.
    Pergunte ao FixBot
    Comentar
  10. Sony Ericsson W810I Camera Replacement: passo 10, imagem 1 %32 Sony Ericsson W810I Camera Replacement: passo 10, imagem 2 %32 Sony Ericsson W810I Camera Replacement: passo 10, imagem 3 %32
    • Insert the plastic opening tool under the ribbon cable attachment and give a small push upwards to dislodge it.
    Pergunte ao FixBot
    Comentar
  11. Sony Ericsson W810I Camera Replacement, LCD Screen: passo 11, imagem 1 %32 Sony Ericsson W810I Camera Replacement, LCD Screen: passo 11, imagem 2 %32 Sony Ericsson W810I Camera Replacement, LCD Screen: passo 11, imagem 3 %32
    • Remove the indicated 6.35mm screws with a Torx T6 screwdriver.
    Pergunte ao FixBot
    Comentar
  12. Sony Ericsson W810I Camera Replacement: passo 12, imagem 1 %32 Sony Ericsson W810I Camera Replacement: passo 12, imagem 2 %32 Sony Ericsson W810I Camera Replacement: passo 12, imagem 3 %32
    • Pull LCD screen gently out and the to side. Do not attempt to pull it completely away from the board below it.
    • Push up on the underside of the cable at the point of attachment with a plastic opening tool to detach it. The screen can now be separated.
    Pergunte ao FixBot
    Comentar
  13. Sony Ericsson W810I Camera Replacement, Motherboard: passo 13, imagem 1 %32 Sony Ericsson W810I Camera Replacement, Motherboard: passo 13, imagem 2 %32 Sony Ericsson W810I Camera Replacement, Motherboard: passo 13, imagem 3 %32
    • Using a plastic opening device, push against the underside of the brown portion of the the ribbon cable to unplug it.
    Pergunte ao FixBot
    Comentar
  14. Sony Ericsson W810I Camera Replacement: passo 14, imagem 1 %32
    • Using a plastic opening device, separate the top of the motherboard from the rest of the plastic casing.
    Pergunte ao FixBot
    Comentar
  15. Sony Ericsson W810I Camera Replacement: passo 15, imagem 1 %32 Sony Ericsson W810I Camera Replacement: passo 15, imagem 2 %32 Sony Ericsson W810I Camera Replacement: passo 15, imagem 3 %32
    • Pull forwards slightly on the motherboard so that it starts to fall out of the casing.
    • Thread the ribbon cable through the hole in the motherboard so that it does not become caught.
    Pergunte ao FixBot
    Comentar
  16. Sony Ericsson W810I Camera Replacement, Camera: passo 16, imagem 1 %32 Sony Ericsson W810I Camera Replacement, Camera: passo 16, imagem 2 %32
    • Push against the underside of the ribbon cable at the point of attachment with a plastic opening tool until it detaches.
    Pergunte ao FixBot
    Comentar
  17. Sony Ericsson W810I Camera Replacement: passo 17, imagem 1 %32
    • Pull the ribbon cable to the side.
    Pergunte ao FixBot
    Comentar
  18. Sony Ericsson W810I Camera Replacement: passo 18, imagem 1 %32 Sony Ericsson W810I Camera Replacement: passo 18, imagem 2 %32
    • Flip over the phone so that the side previously facing you is now facing away.
    • Push gently on the camera module from the side currently facing you. The module should fall away from the plastic mount.
    • Insert the new camera module into the now empty space.
    Pergunte ao FixBot
    Comentar
Conclusão
Uma outra pessoa concluiu este guia.
Lucy Bowen
Membro desde: 09/01/11
473 Reputação
Autoria de 7 guias
Equipe
Cuesta, Team 1-7, Zipperian Fall 2011 Membro de Cuesta, Team 1-7, Zipperian Fall 2011
CUESTA-ZIPPERIAN-F11S1G7
1 Membro
Autoria de 14 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 10
Últimos 30 dias: 45
Ao todo: 4,320
