Ir para o conteúdo principal
Sony Ericsson W810I Camera Lens Replacement
Guia arquivado
Este guia é mantido exclusivamente para fins históricos. Use a versão atualizada do guia para executar o reparo.
O que você precisa
  1. Sony Ericsson W810I Camera Lens Replacement, Camera Lens: passo 1, imagem 1 %32
    • Ensure the phone is switched off. Then press down firmly against the Cingular icon with your thumb.
    • Slide the panel down and remove the latch
  2. Sony Ericsson W810I Camera Lens Replacement: passo 2, imagem 1 %32 Sony Ericsson W810I Camera Lens Replacement: passo 2, imagem 2 %32
    • Lift the battery with your fingers and pull it out of the casing.
    • Remove the SIM card as well if you have one
  3. Sony Ericsson W810I Camera Lens Replacement: passo 3, imagem 1 %32
    • Remove the two outer screws using a T7 Torx screwdriver.
  4. Sony Ericsson W810I Camera Lens Replacement: passo 4, imagem 1 %32
    • Remove the two smaller inner screws with the Mini-Phillips screwdriver.
  5. Sony Ericsson W810I Camera Lens Replacement: passo 5, imagem 1 %32 Sony Ericsson W810I Camera Lens Replacement: passo 5, imagem 2 %32
    • Remove the back faceplate on the camera side with the blue hand wedge.
  6. Sony Ericsson W810I Camera Lens Replacement: passo 6, imagem 1 %32 Sony Ericsson W810I Camera Lens Replacement: passo 6, imagem 2 %32 Sony Ericsson W810I Camera Lens Replacement: passo 6, imagem 3 %32
    • Flip the phone over and pry off the front faceplate using multiple blue hand-wedges.
    • Separate the keypad from the logic board by turning it upside down and allowing it to fall into your hand.
  7. Sony Ericsson W810I Camera Lens Replacement: passo 7, imagem 1 %32
    • Remove the two remaining screws at the top corners of the phone.
  8. Sony Ericsson W810I Camera Lens Replacement: passo 8, imagem 1 %32
    • Remove the logic board with multiple blue hand-wedges. Prise the logic board away carefully to avoid damaging it or snapping the wiring.
  9. Sony Ericsson W810I Camera Lens Replacement: passo 9, imagem 1 %32
    • From the inside of the panel, press down on the camera lens to pop it out of its mounting.
    • Replace the lens and reverse the process to reassemble the device.
Conclusão
Ben Micucci
Membro desde: 10/14/11
186 Reputação
Autoria de 5 guias
Equipe
James Madison, Team 2-2, Allen Fall 2011 Membro de James Madison, Team 2-2, Allen Fall 2011
JMU-ALLEN-F11S2G2
Membros da 2
Autoria de 10 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 7
Últimos 30 dias: 7
Duração total: 1,409
