Ir para o conteúdo principal
Sony Ericsson W580i SIM Card Replacement
O que você precisa
  1. Sony Ericsson W580i SIM Card Replacement, Battery: passo 1, imagem 1 %32 Sony Ericsson W580i SIM Card Replacement, Battery: passo 1, imagem 2 %32 Sony Ericsson W580i SIM Card Replacement, Battery: passo 1, imagem 3 %32
    • Hold the phone with the screen facing down. Push the back cover firmly down and slide it towards you.
    • The panel will slide down about 2mm.
    • Lift the panel away from the phone.
  2. Sony Ericsson W580i SIM Card Replacement: passo 2, imagem 1 %32
    • Lift the battery out from the bottom edge.
  3. Sony Ericsson W580i SIM Card Replacement, SIM Card: passo 3, imagem 1 %32 Sony Ericsson W580i SIM Card Replacement, SIM Card: passo 3, imagem 2 %32 Sony Ericsson W580i SIM Card Replacement, SIM Card: passo 3, imagem 3 %32
    • Locate the SIM card slot.
    • Use a spudger to release the SIM card by pushing it in slightly until you feel a "click."
    • Release pressure from the SIM card. The SIM card will pop out about 5mm.
  4. Sony Ericsson W580i SIM Card Replacement: passo 4, imagem 1 %32 Sony Ericsson W580i SIM Card Replacement: passo 4, imagem 2 %32
    • Slide the SIM card down out of the slot.
    • Remove the SIM card from the phone.
Conclusão
Diego
Membro desde: 10/09/11
388 Reputação
Autoria de 4 guias
Equipe
Cal Poly, Team 5-31, Amido Fall 2011 Membro de Cal Poly, Team 5-31, Amido Fall 2011
CPSU-AMIDO-F11S5G31
Membros da 4
Autoria de 12 guias
Um comentário
where do you get thease parts
Joy Martin - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 13
Últimos 30 dias: 62
Duração total: 12,268
