Introdução
Use this guide to help you replace the LCD.
O que você precisa
Insert the edge of an opening tool between the front cover and the phone.
Gently pry off the front cover working your way around the edges.
Insert a spudger between the lower edge of the screen and the phone.
Pry the screen up to disconnect the tabs on each side holding the screen in.
6 outras pessoas executaram este guia.
