Ir para o conteúdo principal
Sony Ericsson W580i LCD Replacement
O que você precisa
  1. Sony Ericsson W580i LCD Replacement, Front Cover: passo 1, imagem 1 %32 Sony Ericsson W580i LCD Replacement, Front Cover: passo 1, imagem 2 %32
    • Insert the edge of an opening tool between the front cover and the phone.
    • Gently pry off the front cover working your way around the edges.
  2. Sony Ericsson W580i LCD Replacement: passo 2, imagem 1 %32 Sony Ericsson W580i LCD Replacement: passo 2, imagem 2 %32
    • Pull the front cover down and away from the phone.
    • The front keypads might come off with the front cover. Do not lose these.
  3. Sony Ericsson W580i LCD Replacement: passo 3, imagem 1 %32
    • Gently peel the keypad away from the phone.
  4. Sony Ericsson W580i LCD Replacement, LCD: passo 4, imagem 1 %32 Sony Ericsson W580i LCD Replacement, LCD: passo 4, imagem 2 %32
    • Insert a spudger between the lower edge of the screen and the phone.
    • Pry the screen up to disconnect the tabs on each side holding the screen in.
    • Do not remove the screen yet. There is a ribbon connecting the screen to the motherboard.
  5. Sony Ericsson W580i LCD Replacement: passo 5, imagem 1 %32 Sony Ericsson W580i LCD Replacement: passo 5, imagem 2 %32
    • Use a spudger to remove the ribbon cable from the motherboard.
    • Lift the screen away from the phone
Conclusão
6 outras pessoas executaram este guia.
Diego
Membro desde: 10/09/11
397 Reputação
Autoria de 4 guias
Equipe
Cal Poly, Team 5-31, Amido Fall 2011 Membro de Cal Poly, Team 5-31, Amido Fall 2011
CPSU-AMIDO-F11S5G31
4 Membros
Autoria de 12 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 29
Últimos 30 dias: 80
Ao todo: 6,115
