Ir para o conteúdo principal
Sony Ericsson W350a SIM Card Replacement
O que você precisa
  1. Sony Ericsson W350a SIM Card Replacement, Battery: passo 1, imagem 1 %32 Sony Ericsson W350a SIM Card Replacement, Battery: passo 1, imagem 2 %32
    • Place the phone face down on a flat smooth surface so that the camera, logos, and speaker face up.
    • Using the provided notch on the bottom of the back cover, insert a plastic opening tool and lift upwards to remove the back cover of the phone.
  2. Sony Ericsson W350a SIM Card Replacement: passo 2, imagem 1 %32 Sony Ericsson W350a SIM Card Replacement: passo 2, imagem 2 %32 Sony Ericsson W350a SIM Card Replacement: passo 2, imagem 3 %32
    • Set the cover to the side upon removal.
    • Insert the plastic opening tool into the crevice between the camera and the battery of the phone. Using a gentle prying motion, lift the end of the battery and remove.
    • After removal, recycle the defective battery appropriately.
  3. Sony Ericsson W350a SIM Card Replacement, SIM Card: passo 3, imagem 1 %32
    • Slide the SIM card into the lower right slot identified by the circle in the picture, ensuring the contacts are aligned properly.
Conclusão
Uma outra pessoa concluiu este guia.
Parker Stroble
Membro desde: 03/09/12
86 Reputação
Autoria de 3 guias
Equipe
Clemson, Team 1-4, Benson Spring 2012 Membro de Clemson, Team 1-4, Benson Spring 2012
CLEM-BENSON-S12S1G4
Membros da 4
Autoria de 14 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 2
Duração total: 948
