Ir para o conteúdo principal
Sony Ericsson W350a Keypad Replacement
O que você precisa
  1. Sony Ericsson W350a Keypad Replacement, Flip Cover: passo 1, imagem 1 %32
    • Place the plastic opening tool in the bottom corner of the phone in the crevice between the flap to remove the cover.
  2. Sony Ericsson W350a Keypad Replacement: passo 2, imagem 1 %32
    • Remove the cover with a slight twisting motion.
  3. Sony Ericsson W350a Keypad Replacement, Battery: passo 3, imagem 1 %32 Sony Ericsson W350a Keypad Replacement, Battery: passo 3, imagem 2 %32
    • Place the phone face down on a flat smooth surface so that the camera, logos, and speaker face up.
    • Using the provided notch on the bottom of the back cover, insert a plastic opening tool and lift upwards to remove the back cover of the phone.
  4. Sony Ericsson W350a Keypad Replacement: passo 4, imagem 1 %32 Sony Ericsson W350a Keypad Replacement: passo 4, imagem 2 %32 Sony Ericsson W350a Keypad Replacement: passo 4, imagem 3 %32
    • Set the cover to the side upon removal.
    • Insert the plastic opening tool into the crevice between the camera and the battery of the phone. Using a gentle prying motion, lift the end of the battery and remove.
    • After removal, recycle the defective battery appropriately.
  5. Sony Ericsson W350a Keypad Replacement, Speaker: passo 5, imagem 1 %32 Sony Ericsson W350a Keypad Replacement, Speaker: passo 5, imagem 2 %32
    • Flip the phone over and remove the Sony Ericsson sticker that is over the phone's ear speaker.
    • Using a T5 screwdriver, loosen and remove the two screws under the Sony Ericsson sticker by turning them counterclockwise.
  6. Sony Ericsson W350a Keypad Replacement: passo 6, imagem 1 %32
    • Using a mini Phillips screwdriver, remove two screws by turning them counterclockwise.
  7. Sony Ericsson W350a Keypad Replacement: passo 7, imagem 1 %32
    • Insert an opening tool in the bottom crack between the front and back plates and use a gentle upward pull to separate the back case from the front case.
    • Side buttons/controls may fall from their place in between the back and front casings.
  8. Sony Ericsson W350a Keypad Replacement: passo 8, imagem 1 %32
    • Using a T5 screwdriver, remove the two screws by turning them counterclockwise.
  9. Sony Ericsson W350a Keypad Replacement: passo 9, imagem 1 %32 Sony Ericsson W350a Keypad Replacement: passo 9, imagem 2 %32
    • Using an opening tool and a gentle outward motion, separate the front plate from the inner phone workings.
  10. Sony Ericsson W350a Keypad Replacement: passo 10, imagem 1 %32 Sony Ericsson W350a Keypad Replacement: passo 10, imagem 2 %32
    • Using a Phillips head screwdriver, remove the screw from the front number pad by turning it counterclockwise.
    • Remove the speaker from the phone.
  11. Sony Ericsson W350a Keypad Replacement, Keypad: passo 11, imagem 1 %32 Sony Ericsson W350a Keypad Replacement, Keypad: passo 11, imagem 2 %32 Sony Ericsson W350a Keypad Replacement, Keypad: passo 11, imagem 3 %32
    • Disconnect the ribbon cable from its connection until the keypad "pops" off.
    • Remove the keypad from the phone.
Conclusão
Uma outra pessoa concluiu este guia.
Ldellos
Membro desde: 03/12/12
112 Reputação
Autoria de 3 guias
Equipe
Clemson, Team 1-4, Benson Spring 2012 Membro de Clemson, Team 1-4, Benson Spring 2012
CLEM-BENSON-S12S1G4
Membros da 4
Autoria de 14 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 7
Últimos 30 dias: 13
Duração total: 1,262
