Ir para o conteúdo principal
Sony Ericsson W300i Camera Replacement
O que você precisa
  1. Sony Ericsson W300i Camera  Replacement, Camera: passo 1, imagem 1 %32 Sony Ericsson W300i Camera  Replacement, Camera: passo 1, imagem 2 %32
    • The tools you will need for this step is the prying tool and the T6 Torx screwdriver.
  2. Sony Ericsson W300i Camera  Replacement: passo 2, imagem 1 %32 Sony Ericsson W300i Camera  Replacement: passo 2, imagem 2 %32 Sony Ericsson W300i Camera  Replacement: passo 2, imagem 3 %32
    • Remove the back cover of the phone by pushing downwards with your thumbs.
  3. Sony Ericsson W300i Camera  Replacement: passo 3, imagem 1 %32 Sony Ericsson W300i Camera  Replacement: passo 3, imagem 2 %32
    • Now, remove the battery from the phone by gently prying the battery out.
  4. Sony Ericsson W300i Camera  Replacement: passo 4, imagem 1 %32 Sony Ericsson W300i Camera  Replacement: passo 4, imagem 2 %32
    • Remove the front plate from the phone by using the prying tool.
  5. Sony Ericsson W300i Camera  Replacement: passo 5, imagem 1 %32 Sony Ericsson W300i Camera  Replacement: passo 5, imagem 2 %32
    • You now have access to the fours screws that hold the front of the phone together. Remove the four screws.
  6. Sony Ericsson W300i Camera  Replacement: passo 6, imagem 1 %32 Sony Ericsson W300i Camera  Replacement: passo 6, imagem 2 %32
    • Use the prying tool to separate the two parts of the top of the phone
  7. Sony Ericsson W300i Camera  Replacement: passo 7, imagem 1 %32 Sony Ericsson W300i Camera  Replacement: passo 7, imagem 2 %32 Sony Ericsson W300i Camera  Replacement: passo 7, imagem 3 %32
    • Use your fingers to remove the screen and unplug the ribbon cable from the bottom right corner of the back of the screen.
  8. Sony Ericsson W300i Camera  Replacement: passo 8, imagem 1 %32 Sony Ericsson W300i Camera  Replacement: passo 8, imagem 2 %32
    • Now you have access to the camera, which is the silver plate at the bottom of the phone. Remove the camera and replace with a new camera.
Conclusão
Laura Inbody
Membro desde: 02/19/16
7 Reputação
Autoria de 1 guia
Equipe
Ohio State, Team 1-2, Garvin Spring 2016 Membro de Ohio State, Team 1-2, Garvin Spring 2016
OSU-GARVIN-S16S1G2
Membros da 3
Autoria de 4 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 5
Duração total: 356
