Ir para o conteúdo principal
Sony Ericsson W200i Speaker Replacement
O que você precisa
  1. Sony Ericsson W200i Speaker Replacement, Disassembling Sony Ericsson W200i Battery: passo 1, imagem 1 %32 Sony Ericsson W200i Speaker Replacement, Disassembling Sony Ericsson W200i Battery: passo 1, imagem 2 %32
    • Slide the battery cover up and off the phone.
  2. Sony Ericsson W200i Speaker Replacement: passo 2, imagem 1 %32 Sony Ericsson W200i Speaker Replacement: passo 2, imagem 2 %32
    • Pop the battery out of its slot by lifting it up.
  3. Sony Ericsson W200i Speaker Replacement, Front Case: passo 3, imagem 1 %32 Sony Ericsson W200i Speaker Replacement, Front Case: passo 3, imagem 2 %32 Sony Ericsson W200i Speaker Replacement, Front Case: passo 3, imagem 3 %32
    • Insert the plastic opening tool in between the front case and the back case.
    • Apply downward pressure to make the case lift upwards, thus popping the front case off.
    • Use caution when removing the front case. It may seem stuck but just ease it out.
  4. Sony Ericsson W200i Speaker Replacement, Core: passo 4, imagem 1 %32 Sony Ericsson W200i Speaker Replacement, Core: passo 4, imagem 2 %32
    • Remove the 4 screws in the corners of the front of the phone using a T6 screwdriver.
    • Note that the top 2 screws are silver and the bottom 2 screws are black.
  5. Sony Ericsson W200i Speaker Replacement: passo 5, imagem 1 %32 Sony Ericsson W200i Speaker Replacement: passo 5, imagem 2 %32 Sony Ericsson W200i Speaker Replacement: passo 5, imagem 3 %32
    • There is a black tab in the top left corner holding the core in place.
    • Remove the core by pulling straight up to prevent breaking the tab.
  6. Sony Ericsson W200i Speaker Replacement, Back Case: passo 6, imagem 1 %32 Sony Ericsson W200i Speaker Replacement, Back Case: passo 6, imagem 2 %32 Sony Ericsson W200i Speaker Replacement, Back Case: passo 6, imagem 3 %32
    • Pull back on the indicated tab of the white plastic cover to unhook it from the top of the phone.
    • Using the plastic opening tool, undo the indicated clip on the bottom of the white plastic cover.
    • Remove the white plastic cover.
  7. Sony Ericsson W200i Speaker Replacement, Speaker: passo 7, imagem 1 %32 Sony Ericsson W200i Speaker Replacement, Speaker: passo 7, imagem 2 %32
    • Remove the speaker by pulling it up and out of place with the tweezers.
Conclusão
Andy Whitmyre
Membro desde: 01/12/11
147 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team 14-10, Forte Winter 2011 Membro de Cal Poly, Team 14-10, Forte Winter 2011
CPSU-FORTE-W11S14G10
Membros da 5
Autoria de 16 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 2
Duração total: 4,816
