Ir para o conteúdo principal
Fix Your Stuff
Right to Repair
Parts & Tools
Introdução
Removing the front case is easy, just be careful when you take it off.
Peças
Nenhum componente especificado.
  1. Insert the plastic opening tool in between the front case and the back case. Apply downward pressure to make the case lift upwards, thus popping the front case off. Use caution when removing the front case. It may seem stuck but just ease it out.
    • Insert the plastic opening tool in between the front case and the back case.
    • Apply downward pressure to make the case lift upwards, thus popping the front case off.
    • Use caution when removing the front case. It may seem stuck but just ease it out.
Conclusão
To reassemble your device, follow these instructions in reverse.
Uma outra pessoa concluiu este guia.
Emily Prescott
Membro desde: 10-01-2011
476 Reputation
4 Guias de autoria
Equipe
Cal Poly, Team 14-10, Forte Winter 2011 Membro de Cal Poly, Team 14-10, Forte Winter 2011
CPSU-FORTE-W11S14G10
5 Membros
16 Guias de autoria
Adicione um comentário
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 2,701
