Introdução
Replacing the case is fairly easy, there will be small parts you will be removing so make sure you have a place to put them for safe-keeping.
O que você precisa
Slide the battery cover up and off the phone.
Insert the plastic opening tool in between the front case and the back case.
Apply downward pressure to make the case lift upwards, thus popping the front case off.
Remove the 4 screws in the corners of the front of the phone using a T6 screwdriver.
Pull back on the indicated tab of the white plastic cover to unhook it from the top of the phone.
Using the plastic opening tool, undo the indicated clip on the bottom of the white plastic cover.
Remove the white plastic cover.
To reassemble your device, put removed pieces into the new back casing, then follow the steps in reverse order.
