Este guia tem alterações mais recentes. Mudar para a última versão não verificada.
Introdução
This guide provides instruction for installing a ribbon containing a speaker, GPS and camera for the Sony Ericsson TM506 cell phone.
O que você precisa
Firmly hold the phone between your fingers with your thumb on the battery cover.
Push down with your thumb until the battery cover comes off.
The sound box is attached to the case by two snap hooks.
Lift the sound box up to remove it from the case.
Locate the 80-pin connector.
Carefully, lift up on the connector to separate it from the board.
Use tweezers to push the hinge stopper in until it can no longer be moved.
The hinge stopper should be about 5.5mm in.
