Ir para o conteúdo principal
Sony Ericsson T68i Microphone Replacement
O que você precisa
  1. Sony Ericsson T68i Microphone Replacement, Keypad: passo 1, imagem 1 %32 Sony Ericsson T68i Microphone Replacement, Keypad: passo 1, imagem 2 %32
    • Remove the battery from the back.
  2. Sony Ericsson T68i Microphone Replacement: passo 2, imagem 1 %32 Sony Ericsson T68i Microphone Replacement: passo 2, imagem 2 %32 Sony Ericsson T68i Microphone Replacement: passo 2, imagem 3 %32
    • Pry off the plastic cover from the top with a thin plastic shim, then remove it from the two bottom clips.
    • Do not bend it too far down, or else you risk breaking the two bottom clips.
  3. Sony Ericsson T68i Microphone Replacement: passo 3, imagem 1 %32 Sony Ericsson T68i Microphone Replacement: passo 3, imagem 2 %32 Sony Ericsson T68i Microphone Replacement: passo 3, imagem 3 %32
    • Unscrew all four Torx T6 screws.
    • Keep in a safe place.
  4. Sony Ericsson T68i Microphone Replacement: passo 4, imagem 1 %32 Sony Ericsson T68i Microphone Replacement: passo 4, imagem 2 %32 Sony Ericsson T68i Microphone Replacement: passo 4, imagem 3 %32
    • After removing the screws, the two halves will separate. If not, then pry them gently apart.
  5. Sony Ericsson T68i Microphone Replacement, Microphone: passo 5, imagem 1 %32 Sony Ericsson T68i Microphone Replacement, Microphone: passo 5, imagem 2 %32 Sony Ericsson T68i Microphone Replacement, Microphone: passo 5, imagem 3 %32
    • Next remove the circuit board and screen from the device.
    • Use your T6 to remove the 4 screws holding the cover on.
  6. Sony Ericsson T68i Microphone Replacement: passo 6, imagem 1 %32 Sony Ericsson T68i Microphone Replacement: passo 6, imagem 2 %32 Sony Ericsson T68i Microphone Replacement: passo 6, imagem 3 %32
    • The board and screen should just pop out at this point.
  7. Sony Ericsson T68i Microphone Replacement: passo 7, imagem 1 %32 Sony Ericsson T68i Microphone Replacement: passo 7, imagem 2 %32
    • The microphone at the bottom of the rear housing can be levered out using a small screwdriver or any similar tool.
Conclusão
Uma outra pessoa concluiu este guia.
Tim Dascomb
Membro desde: 04/13/10
159 Reputação
Autoria de 7 guias
Equipe
Cal Poly, Team 26-34, Regan Spring 2010 Membro de Cal Poly, Team 26-34, Regan Spring 2010
CPSU-REGAN-S10S26G34
Membros da 4
Autoria de 13 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 2
Duração total: 2,170
