Introdução
This guide will assist you in removing the logic board from your Sony Ericsson T68i.
Peças
Não são necessárias peças.
  1. Remove the battery from the back. Remove the battery from the back.
    • Remove the battery from the back.
  2. Pry off the plastic cover from the top with a thin plastic shim, then remove it from the two bottom clips. Do not bend it too far down, or else you risk breaking the two bottom clips. Do not bend it too far down, or else you risk breaking the two bottom clips.
    • Pry off the plastic cover from the top with a thin plastic shim, then remove it from the two bottom clips.
    • Do not bend it too far down, or else you risk breaking the two bottom clips.
  3. Unscrew all four Torx T6 screws. Keep in a safe place. Keep in a safe place.
    • Unscrew all four Torx T6 screws.
    • Keep in a safe place.
  4. Free shipping on all orders over US$100 or containing a Pro Tech Toolkit!
    Visite Nossa Loja
  5. After removing the screws, the two halves will separate. If not, then pry them gently apart. After removing the screws, the two halves will separate. If not, then pry them gently apart. After removing the screws, the two halves will separate. If not, then pry them gently apart.
    • After removing the screws, the two halves will separate. If not, then pry them gently apart.
  6. Remove the circuit board and screen from the device. Use your T6 to remove the 4 screws. Use your T6 to remove the 4 screws.
    • Remove the circuit board and screen from the device.
    • Use your T6 to remove the 4 screws.
  7. Remove the board and screen. Remove the board and screen. Remove the board and screen.
    • Remove the board and screen.
  8. Carefully remove the plastic clips holding the screen on the board. Carefully remove the plastic clips holding the screen on the board. Carefully remove the plastic clips holding the screen on the board.
    • Carefully remove the plastic clips holding the screen on the board.
  9. Remove the plate protecting the more delicate processing parts from the logic board. Remove the plate protecting the more delicate processing parts from the logic board. Remove the plate protecting the more delicate processing parts from the logic board.
    • Remove the plate protecting the more delicate processing parts from the logic board.
Conclusão
Tim Dascomb
123 reputação
7 Guides authored
Equipe
Cal Poly, Team 26-34, Regan Spring 2010 Membro de Cal Poly, Team 26-34, Regan Spring 2010
CPSU-REGAN-S10S26G34
4 Membros
13 Guides authored
Visualizar Estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Todo: 1,893
