Ir para o conteúdo principal
Sony Ericsson QuickShare T630 Screen Replacement
O que você precisa
  1. Sony Ericsson QuickShare T630 Screen Replacement, Sony Ericsson QuickShare T630 Phone Enclosure: passo 1, imagem 1 %32
    • Begin the disassembly by placing your Sony Ericsson QuickShare T630 on a flat surface.
  2. Sony Ericsson QuickShare T630 Screen Replacement: passo 2, imagem 1 %32 Sony Ericsson QuickShare T630 Screen Replacement: passo 2, imagem 2 %32
    • Slide the protective panel on the backside of the phone downward and remove it entirely, revealing the battery underneath.
  3. Sony Ericsson QuickShare T630 Screen Replacement: passo 3, imagem 1 %32
    • Slide the battery upward to remove.
  4. Sony Ericsson QuickShare T630 Screen Replacement: passo 4, imagem 1 %32 Sony Ericsson QuickShare T630 Screen Replacement: passo 4, imagem 2 %32
    • Remove the rubber plug located near the camera by gently prying upward with your fingers.
    • Gently lift the camera shield after removal of the rubber plug.
  5. Sony Ericsson QuickShare T630 Screen Replacement: passo 5, imagem 1 %32 Sony Ericsson QuickShare T630 Screen Replacement: passo 5, imagem 2 %32
    • Pry the remaining panel to loosen its contact to the phone using a spudger.
    • Slide the panel upward to remove it completely.
    • These steps will require a slight appliance of force.
  6. Sony Ericsson QuickShare T630 Screen Replacement: passo 6, imagem 1 %32
    • Slide the aerial upward to remove it.
  7. Sony Ericsson QuickShare T630 Screen Replacement: passo 7, imagem 1 %32 Sony Ericsson QuickShare T630 Screen Replacement: passo 7, imagem 2 %32
    • Remove the four screws located at each corner of the device.
  8. Sony Ericsson QuickShare T630 Screen Replacement: passo 8, imagem 1 %32 Sony Ericsson QuickShare T630 Screen Replacement: passo 8, imagem 2 %32
    • Gently lift and remove the front panel of the phone after removing the screws.
  9. Sony Ericsson QuickShare T630 Screen Replacement: passo 9, imagem 1 %32 Sony Ericsson QuickShare T630 Screen Replacement: passo 9, imagem 2 %32 Sony Ericsson QuickShare T630 Screen Replacement: passo 9, imagem 3 %32
    • This step is NOT required for joystick maintenance or keypad maintenance and replacement! Continue on to step 10 if you are attempting to achieve either of these goals.
    • Slowly lift the screen to reveal the green circuit ribbon connecting the screen to the phone.
    • Gently pull the ribbon from the circuit.
    • Remove the now disconnected screen.
  10. Sony Ericsson QuickShare T630 Screen Replacement: passo 10, imagem 1 %32 Sony Ericsson QuickShare T630 Screen Replacement: passo 10, imagem 2 %32 Sony Ericsson QuickShare T630 Screen Replacement: passo 10, imagem 3 %32
    • Remove the keyboard by slowly pulling it away from the circuit board.
    • There are no direct connections between the keyboard and phone.
    • These are all of the parts covered in this disassembly that make up the Sony Ericsson QuickShare T630.
  11. Sony Ericsson QuickShare T630 Screen Replacement, Sony Ericsson QuickShare T630 Screen: passo 11, imagem 1 %32 Sony Ericsson QuickShare T630 Screen Replacement, Sony Ericsson QuickShare T630 Screen: passo 11, imagem 2 %32 Sony Ericsson QuickShare T630 Screen Replacement, Sony Ericsson QuickShare T630 Screen: passo 11, imagem 3 %32
    • To place a new screen, slide the green ribbon connector into the ribbon clamp that the defective screen was pulled from.
Conclusão
Uma outra pessoa concluiu este guia.
Jeremy
Membro desde: 10/16/13
166 Reputação
Autoria de 1 guia
Equipe
University of Maine, Team 1-1, Diaz Fall 2013 Membro de University of Maine, Team 1-1, Diaz Fall 2013
UMAINE-DIAZ-F13S1G1
Membros da 4
Autoria de 6 guias
Um comentário
Worked well until the screen replacemet - ribbon cable would not go into clamp - phone plus new screen straight in the bin - a little gutted - but hey it was an old but loved phone.
roger hiley - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 16
Duração total: 1,335
