Introdução
Screens for cellular devices are prone to cracking or shattering. There are several prerequisite steps required to access and remove the screen in place in your device. This guide will show you how to access the screen in order to replace in.
Peças
Não são necessárias peças.
  1. Begin the disassembly by placing your Sony Ericsson QuickShare T630 on a flat surface.
    • Begin the disassembly by placing your Sony Ericsson QuickShare T630 on a flat surface.
  2. Slide the protective panel on the backside of the phone downward and remove it entirely, revealing the battery underneath. Slide the protective panel on the backside of the phone downward and remove it entirely, revealing the battery underneath.
    • Slide the protective panel on the backside of the phone downward and remove it entirely, revealing the battery underneath.
  3. Slide the battery upward to remove.
    • Slide the battery upward to remove.
  4. Remove the rubber plug located near the camera by gently prying upward with your fingers. Gently lift the camera shield after removal of the rubber plug.
    • Remove the rubber plug located near the camera by gently prying upward with your fingers.
    • Gently lift the camera shield after removal of the rubber plug.
  5. Free shipping on all orders over US$100,00 or containing a Pro Tech Toolkit!
    Visite Nossa Loja
  6. Pry the remaining panel to loosen its contact to the phone using a spudger. Slide the panel upward to remove it completely.
    • Pry the remaining panel to loosen its contact to the phone using a spudger.
    • Slide the panel upward to remove it completely.
    • These steps will require a slight appliance of force.
  7. Slide the aerial upward to remove it.
    • Slide the aerial upward to remove it.
  8. Locate screws on four corners of device Remove the screws
    • Locate screws on four corners of device
    • Remove the screws
  9. Gently lift and remove the front panel of the phone after removing the screws. Gently lift and remove the front panel of the phone after removing the screws.
    • Gently lift and remove the front panel of the phone after removing the screws.
  10. This step is NOT required for joystick maintenance or keypad maintenance and replacement! Continue on to step 10 if you are attempting to achieve either of these goals. Slowly lift the screen to reveal the green circuit ribbon connecting the screen to the phone. Gently pull the ribbon from the circuit/
    • This step is NOT required for joystick maintenance or keypad maintenance and replacement! Continue on to step 10 if you are attempting to achieve either of these goals.
    • Slowly lift the screen to reveal the green circuit ribbon connecting the screen to the phone.
    • Gently pull the ribbon from the circuit/
    • Remove the now disconnected screen.
  11. Remove the keyboard by slowly pulling it away from the circuit board. There are no direct connections between the keyboard and phone. These are all of the parts covered in this disassembly that make up the Sony Ericsson QuickShare T630.
    • Remove the keyboard by slowly pulling it away from the circuit board.
      • There are no direct connections between the keyboard and phone.
      • These are all of the parts covered in this disassembly that make up the Sony Ericsson QuickShare T630.
  12. To place a new screen, slide the green ribbon connector into the ribbon clamp that the defective screen was pulled from. Replacement screens for purchase Replacement screens for purchase
Conclusão
Uma outra pessoa concluiu este guia.
Jeremy
156 reputação
Autoria de 1 guia
Equipe
Worked well until the screen replacemet - ribbon cable would not go into clamp - phone plus new screen straight in the bin - a little gutted - but hey it was an old but loved phone.
roger hiley - Responder
Visualizar Estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 5
Todo: 1,019
