Ir para o conteúdo principal
Sony Ericsson J22Oi Charging Port Replacement
O que você precisa
  1. Sony Ericsson J22Oi Charging Port Replacement, Battery: passo 1, imagem 1 %32
    • Before disassembling the phone, make sure the phone is powered off.
  2. Sony Ericsson J22Oi Charging Port Replacement: passo 2, imagem 1 %32
    • Flip to the back of the phone and locate the black button on the top of the phone.
  3. Sony Ericsson J22Oi Charging Port Replacement: passo 3, imagem 1 %32
    • Firmly hold down the black button on the top of the phone and gently snap off the back cover.
  4. Sony Ericsson J22Oi Charging Port Replacement: passo 4, imagem 1 %32
    • Remove the battery by wedging it out from the back.
  5. Sony Ericsson J22Oi Charging Port Replacement, Keypad: passo 5, imagem 1 %32
    • Flip to the front of the phone and apply pressure to the front frame of the phone. The frame should snap off easily.
  6. Sony Ericsson J22Oi Charging Port Replacement: passo 6, imagem 1 %32
    • Remove the keypad by gently pulling it from the front of the phone.
  7. Sony Ericsson J22Oi Charging Port Replacement, Screen: passo 7, imagem 1 %32
    • Locate the five screws indicated on the phone.
  8. Sony Ericsson J22Oi Charging Port Replacement: passo 8, imagem 1 %32
    • Use a T5 Screwdriver and unscrew the five screws.
  9. Sony Ericsson J22Oi Charging Port Replacement: passo 9, imagem 1 %32
    • Once the screws are off, there should be a plastic cover on top of your screen. Gently slide the plastic cover off.
  10. Sony Ericsson J22Oi Charging Port Replacement: passo 10, imagem 1 %32
    • Now gently pull metal cover off.
  11. Sony Ericsson J22Oi Charging Port Replacement: passo 11, imagem 1 %32
    • You should now see the screen on the front side of the phone. Wedge your finger to the side of the phone. Apply some force to pop out the screen.
  12. Sony Ericsson J22Oi Charging Port Replacement: passo 12, imagem 1 %32
    • Now that screen is removed, replace the old screen with the new screen.
    • Reassemble the device by doing the steps in reverse order.
  13. Sony Ericsson J22Oi Charging Port Replacement, Charging Port: passo 13, imagem 1 %32
    • After removing the screen, you will find the charging port located at the bottom of the phone.
  14. Sony Ericsson J22Oi Charging Port Replacement: passo 14, imagem 1 %32
    • Gently slide off the charging port.
Conclusão
James Au
Membro desde: 10/06/12
10 Reputação
Autoria de 4 guias
Equipe
Cal Poly, Team 6-36, Regan Fall 2012 Membro de Cal Poly, Team 6-36, Regan Fall 2012
CPSU-REGAN-F12S6G36
Membros da 3
Autoria de 10 guias
Um comentário
Nice information for me , I also repairing the mobile phone
Mohit - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 14
Duração total: 1,368
