Ir para o conteúdo principal
Sony ECM-MS907 Battery Replacement
O que você precisa
  1. Sony ECM-MS907 Battery Replacement, Battery: passo 1, imagem 1 %32
    • Take off the windshield from the top of the microphone and place aside. The bottom part of the microphone is detachable. In a clockwise motion, begin unscrewing the bottom of the microphone from its base.
  2. Sony ECM-MS907 Battery Replacement: passo 2, imagem 1 %32 Sony ECM-MS907 Battery Replacement: passo 2, imagem 2 %32
    • Pull off the bottom base of the microphone. The microphone should now be in two pieces. After the bottom base is removed, the battery should now be visible.
  3. Sony ECM-MS907 Battery Replacement: passo 3, imagem 1 %32
    • To remove the battery, push it upward into the aluminum spring. This will loosen and free the battery.
  4. Sony ECM-MS907 Battery Replacement: passo 4, imagem 1 %32 Sony ECM-MS907 Battery Replacement: passo 4, imagem 2 %32
    • Select a new, (AA) battery to insert into the microphone. Match the (+) and (-) sides of the battery to the matching symbols inside the microphone.
Conclusão
3 outras pessoas executaram este guia.
Kefaya
Membro desde: 01/23/14
364 Reputação
Autoria de 3 guias
Equipe
2 comentários
Excellent tuto : clair direct et simple
Une fois avoir changé la pile, j’ai découvert qu’il y a un mauvais contact avec le bouton de commande. Quand on le manipule, le voyant s’allume 1/4 de secondes et s’éteint. Pourriez vous ‘m’indiquer un tuto pour le démontage complet du microphone Sony.
Ou bien m’indiquer un réparateur sur Paris
Merci à Kefaya et bonne soirée
henri75012@club-internet.fr
Biezin - Responder
Remarquable tuto, illustré par de magnifiques photos, très claires. Merci beaucoup !
DENIS PERRIN - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 14
Duração total: 4,972
