Ir para o conteúdo principal
Sony Dream Machine ICF-C717PJ Battery Replacement
O que você precisa
  1. Sony Dream Machine ICF-C717PJ Battery Replacement, Battery: passo 1, imagem 1 %32
    • To start, use a small phillips screwdriver, to remove the screw located on the battery component on the back of the device.
  2. Sony Dream Machine ICF-C717PJ Battery Replacement: passo 2, imagem 1 %32 Sony Dream Machine ICF-C717PJ Battery Replacement: passo 2, imagem 2 %32
    • Once you have removed the screw from the battery cover, pull out the cover using your fingers.
  3. Sony Dream Machine ICF-C717PJ Battery Replacement: passo 3, imagem 1 %32
    • Remove the remaining screws from the back of the clock.
    • Set them aside for reassembly
  4. Sony Dream Machine ICF-C717PJ Battery Replacement: passo 4, imagem 1 %32 Sony Dream Machine ICF-C717PJ Battery Replacement: passo 4, imagem 2 %32
    • Remove the back panel of the clock, pry open with screwdriver if necessary.
    • Ensure that the red wires connecting the back panel and the main device are not frayed or damage before proceeding to the next step.
Conclusão
Uma outra pessoa concluiu este guia.
Equipe
UW Tacoma, Team S1-G3, Liner Summer 2018 Membro de UW Tacoma, Team S1-G3, Liner Summer 2018
UWT-LINER-SU18S1G3
Membros da 4
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 9
Últimos 30 dias: 36
Duração total: 1,882
