Ir para o conteúdo principal
Sony Dream Machine ICF-C180 Speaker Replacement
O que você precisa
  1. Sony Dream Machine ICF-C180 Speaker Replacement, Speaker: passo 1, imagem 1 %32 Sony Dream Machine ICF-C180 Speaker Replacement, Speaker: passo 1, imagem 2 %32 Sony Dream Machine ICF-C180 Speaker Replacement, Speaker: passo 1, imagem 3 %32
    • Detach the top of the plastic casing. Use a Phillips head screwdriver to unscrew the three bottom screws.
  2. Sony Dream Machine ICF-C180 Speaker Replacement: passo 2, imagem 1 %32 Sony Dream Machine ICF-C180 Speaker Replacement: passo 2, imagem 2 %32
    • Wedge a plastic opening tool between the face of the clock and the body.
    • Pry open the face of the clock away from the body.
  3. Sony Dream Machine ICF-C180 Speaker Replacement: passo 3, imagem 1 %32 Sony Dream Machine ICF-C180 Speaker Replacement: passo 3, imagem 2 %32
    • To open the top casing, pull it upward.
    • Be careful not to yank on the ribbon cable when pulling on the top casing.
  4. Sony Dream Machine ICF-C180 Speaker Replacement: passo 4, imagem 1 %32 Sony Dream Machine ICF-C180 Speaker Replacement: passo 4, imagem 2 %32
    • Pull upward on the blue and white ribbon cables to remove them. This will make it easier to remove the speaker.
  5. Sony Dream Machine ICF-C180 Speaker Replacement: passo 5, imagem 1 %32 Sony Dream Machine ICF-C180 Speaker Replacement: passo 5, imagem 2 %32
    • Desolder the wires going to the speaker with a soldering iron.
  6. Sony Dream Machine ICF-C180 Speaker Replacement: passo 6, imagem 1 %32 Sony Dream Machine ICF-C180 Speaker Replacement: passo 6, imagem 2 %32
    • Use the plastic opening tool to remove the glue from the speaker.
  7. Sony Dream Machine ICF-C180 Speaker Replacement: passo 7, imagem 1 %32 Sony Dream Machine ICF-C180 Speaker Replacement: passo 7, imagem 2 %32
    • Loosen the speaker from the remaining glue with a plastic opening tool.
    • Insert the plastic opening tool into the rail that holds the speaker and push down.
  8. Sony Dream Machine ICF-C180 Speaker Replacement: passo 8, imagem 1 %32 Sony Dream Machine ICF-C180 Speaker Replacement: passo 8, imagem 2 %32
    • Pull the speaker upward to remove it.
Conclusão
Uma outra pessoa concluiu este guia.
Caleb John
Membro desde: 05/31/16
101 Reputação
Autoria de 1 guia
Um comentário
HEY! that's moderately adequate...
Caleb John - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 5
Duração total: 483
